Timer With Manual Overide? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 11:59 AM   #1
Rewards Points: 137
Timer with manual overide?
I have my outside lights connected to a digital timer to come on and off each night. I have them go off everyday at 11pm. I would like to also be able to turn them on manually with a regular switch after 11pm in case I have company leaving later then 11pm. Can I just run a switch that will jump the timer?
Troy32 is offline   Reply With Quote
Old 12-11-2012, 01:34 PM   #2
Rewards Points: 320
Possibly. Which timer do you have? The timer doesn't have a manual override switch? The mechanical timers made by intermatic are very simple and have a manual on switch.
teamo is offline   Reply With Quote
Old 12-11-2012, 02:40 PM   #3
Rewards Points: 137
It is a little digital timer that fits in switchplate. I am not sure of the brand. It does have a manual overide but I have it in the basement. I would like to be able to use the switch by the front door to overide it.
Old 12-11-2012, 03:58 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Are the outside lights you want to control line voltage or low voltage?
What does the switch by the front door control now?
Coastal South Carolina
Old 12-11-2012, 04:06 PM   #5
Rewards Points: 137
The lights are regular 110v lights. The switch did control the lights but now I ran the lights to the timer. The switch currently does nothing. I just wanted to jump the timer with the switch so I can still turn on the lights when the timer goes off rather then run down into the basement to use the timers over ride.
Old 12-11-2012, 04:22 PM   #6
Rewards Points: 320
You can run a switch leg with the switch that you have. Do you have to pull a new cable to the switch that you want to use?
Old 12-11-2012, 04:26 PM   #7
A "Handy Husband"
rjniles's Avatar
If the lights are still on the same circuit (breaker) as the switch, just connect the switched hot from the switch to the output switched hot of the timer.
How you do that will depend on how your specific wiring is run.
I assume you know how you reconfigured the wiring to add the timer.
Old 12-11-2012, 04:29 PM   #8
Rewards Points: 137
Yes, I already snaked a wire throught the wall into the basement for the switch.
I was just about to run the two switch wires from the hot input on the timer to the hot output to over ride it but just wanted to make sure this would be safe.
Old 12-11-2012, 04:30 PM   #9
Rewards Points: 137
cureently the switch is not connected to anything
GE 15312 Timer installation tbdbitl Electrical 1 12-13-2012 04:40 PM
Help with Pool Timer Intermatic P1353ME TGMcCallie Electrical 4 08-03-2012 08:44 PM
aube timer manual walter tigar Electrical 3 07-04-2012 07:25 PM
Wall Timer Wiring Issue sjh5g Electrical 18 02-16-2012 11:57 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
