Timer Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2008, 09:20 AM   #1
Timer Installation
I just purchased a new timer for the jets in our jetted bathtub.
The Old Timer is hooked up simply (and obviously):
black -> brass / white -> silver
The new timer has 4 wires coming out of it (Red, White, Black, Green).
I've wired:
Black (Timer) -> Black (Box)
Green (Timer) -> Ground (box)
Now i'm stuck as to what to hook up.... any help?
lpmike82 is offline   Reply With Quote
Old 06-21-2008, 09:37 AM   #2
Electrician
Rewards Points: 792
What are the specs on your old timer and the specs on the new one.
It sounds like your old one may be 120V and the new one is a 240V/120V timer.
You will need to give us more information on the timers to best answer your question
darren is offline   Reply With Quote
Old 06-21-2008, 10:19 AM   #3
Rewards Points: 130
Why don't you look at the directions that came with the timer. There will be a wiring diagram in it, or on the box. If you bought it from the tub manufacturer you may need to call them or go to their web site for a manual.
You do not have the correct timer for your tub. Unless the red and black go together.
PS.....Do you have a meter. If so we can help.
Old 06-21-2008, 02:58 PM   #4
Advice worth 2 cents!
Rewards Points: 150
My first guess..
Black to power
White to neutral (always)
Red to jet pump
Green to box
-pete
Some digital timers need the neutral, the old mechanical types didn't nor do the very low power ones.
---pete
HandyPete is offline   Reply With Quote
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
dryer timer auto cycles don't work mikedudl Appliances 6 04-29-2008 07:48 PM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Adding a timer to my outdoor house lighting ConstantChange Electrical 2 03-31-2007 08:56 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
