Timer Enclosure As A Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 06:14 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Timer enclosure as a junction box?
I have a landscape lighting system that I am reworking to eliminate a mechanical timer and install an digital timer. The circuit runs from the breaker panel to a mechanical timer* in a metal enclosure to the receptacle that the lighting transformer is plugged into. This will give me constant power at the receptacle which is my goal. Since the wiring is in conduit it will be hard (or impossible without replacing the existing wiring) to replace the timer enclosure with a standard junction box.
* Like this one but mine is rated at 20 amps
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I would like to pull the guts out of the metal timer enclosure and wire nut the input and output cables together and use this as a junction box. Question is : Is it code complliant to use the timer's metal case as a junction box?
Coastal South Carolina
Old 11-22-2010, 06:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Leave the guts in and make the connection.
Intermatic EH40 Water Heater Timer datgrt Electrical 6 05-09-2014 08:14 PM
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
timer requires a 40 watt min. load, I only have 10...now what? glassbird Electrical 3 08-18-2010 11:32 AM
Mechanical timer wiring? Duane 70 Electrical 5 06-16-2010 08:57 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
