Old 02-10-2008, 09:05 AM   #1
Tiling aroung electrical outlet?
I am redoing my kitchen backsplash and I have a 2 gang box with 2 outlets.
I have the boxes out of the drywall now (just a hole).
What type of box should I get so I can tile around the outlet?
Should I get a "mud ring" and if so, how close to the ring do I tile to?
I guess I just want to make sure the plate covers the tile edges?
Thanks,
Matt
sandyman720 is offline   Reply With Quote
Old 02-10-2008, 10:58 AM   #2
I would suggest getting two gangable old work boxes or a two gang old work box. Buy the box and cover before you tile, and you will be able to hold a ruler up to them to determine the size of the hole you need.
Master Electrician
jwhite is offline   Reply With Quote
Old 02-10-2008, 04:26 PM   #3
Your 2G box is fine. A mud ring goes on a 4 square box.
Be sure and cut your tile allowing room for the GFCI/decora switch cover plate screws which are about 1/4 inch above the device screws. If you cut the holes too tight the screws tend to stop when the hit the tile. It is a very precise cut because you want the plaster ears to hit the tile but not the cp screw.
If you use nylon covers you can float the devices out a touch and the plates will secure them without breaking.
220/221 is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 08:59 PM
