-   -   Tiling aroung electrical outlet? (http://www.diychatroom.com/f18/tiling-aroung-electrical-outlet-16857/)
sandyman720 02-10-2008 08:05 AM
I am redoing my kitchen backsplash and I have a 2 gang box with 2 outlets.
I have the boxes out of the drywall now (just a hole).
What type of box should I get so I can tile around the outlet?
Should I get a "mud ring" and if so, how close to the ring do I tile to?
I guess I just want to make sure the plate covers the tile edges?
Thanks,
Matt
jwhite 02-10-2008 09:58 AM
I would suggest getting two gangable old work boxes or a two gang old work box. Buy the box and cover before you tile, and you will be able to hold a ruler up to them to determine the size of the hole you need.
220/221 02-10-2008 03:26 PM
Your 2G box is fine. A mud ring goes on a 4 square box.
Be sure and cut your tile allowing room for the GFCI/decora switch cover plate screws which are about 1/4 inch above the device screws. If you cut the holes too tight the screws tend to stop when the hit the tile. It is a very precise cut because you want the plaster ears to hit the tile but not the cp screw.
If you use nylon covers you can float the devices out a touch and the plates will secure them without breaking.
