Tiling Around HALF An Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 11:04 AM   #1
Physics Teacher and DIYer
Rewards Points: 18
Tiling around HALF an electrical outlet
Hi,
Hope this wasn't addressed elsewhere - couldn't find it if it was.
I'm a new DIYer who decided to completely gut and redo my bathroom. I tried to plan ahead as much as possible and avoided many problems. What I didn't consider was that my wall tile (4' high off floor) would cut right through the middle of the electrical outlet and the light switch. The problem is that this will not allow the cover plates to sit flush. I'm looking for possible solutions.
I can't tile any higher (12" x 16" tile so I can't just add another row). Nor can I go lower a this point. The top row of tile will be 2 rows of 1x1 glass tile so I thought of wraping this around the outlet but I don't want to if I don't have to.
Any suggestions would be most welcome.
thanks.
Patless is offline   Reply With Quote
Old 10-06-2009, 11:49 AM   #2
Rewards Points: 204
Move the box. It should be easy to move if you are remodeling.
If it worked before you worked on it. You did something wrong.
Old 10-06-2009, 12:27 PM   #3
300zx's Avatar
Post
Not sure if i understand what you are talking about but if the rec is where the tile will be cut the outlets out on the tile and then when you go to put them back in you will need longer screws 2 inch drywall screws will work then you can pick these up at lowes or hd pretty cheap it holds the outlet and the switch in place we use the all the time for tile backsplash If that was what you wanted to know? We call them spark guards
300zx is offline   Reply With Quote
Old 10-06-2009, 12:38 PM   #4
Licensed Pro
Originally Posted by Patless View Post
Hi,
thanks.
Move the boxes or wrap the tile around the boxes.
Old 10-06-2009, 12:53 PM   #5
Rewards Points: 18
Don't know why I didn't think of moving the boxes - thanks, that will be easy enough. Just wondered if there was some novel suggestion or product out there.
cheers.
Old 10-06-2009, 07:27 PM   #6
Household Handyman
Rewards Points: 1,408
I read all of the post, my vote:
Move the box.
Good Luck, David
Old 10-06-2009, 07:40 PM   #7
Thumbs up
Issue of extending box!
As 300ZX (Poster #3) pointed out. Sometimes, they're called Box extensions. That's easier than moving the box. In any case, if you're installing "Decora" receptacles or switches be certain to chip off the tile (top and bottom) where the screws for the plate go. It will interfere with the screws (even if they are short). (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-06-2009, 07:59 PM   #8
Move it up or move it down. Sometimes it is really easy. Other times, not so much. Moving the box up is generally easier than moving it down. When you pull the switch out you will see how many cables are in it and if the come from the top or bottom. This will help determine which way to go with it.
If it's a newer house with a plastic nail on box it will be easy. Pry the box loose from the stud, deal with any staples that may restrict movement and slide it to it's new location and rescrew it thru the box to the wall.
I have seen switches and receps tiled around and they look like crap
220/221 is offline   Reply With Quote
Old 10-06-2009, 08:24 PM   #9
300zx's Avatar
Post
I don't know if we are talking about the same thing if the outlet will have tile around it use a sparkgaurd or Box extensions to bring the outlet to the right place works good. I think they look good when done
Old 10-06-2009, 08:39 PM   #10
He is talking about the horizontal plane at the top of his tile, half way up the wall.
Old 10-07-2009, 10:39 AM   #11
Rewards Points: 18
Well, it will be a little higher than I wanted if I move it up (too late to go down), but sounds like the easiest solution, especially since tiling around isn't ideal asthetically.
half the outlet is not working tskmercer Electrical 14 01-17-2009 03:18 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
Adding an electrical outlet box helpless handyman Electrical 14 07-06-2007 07:59 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
