Tiled Walls, Now The Outlet And Light Switch Are Too Deep! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 05:12 PM   #1
long island, NY
tiled walls, now the outlet and light switch are too deep!
I avoid electrical work... the most I've ever done is hardwire chandeliers. That being said, my gut says that this is a really trivial problem.
The tile is very thick, so now, the switch and outlet are about 1" too recessed into the wall now. How does one deal with this? I guess it would require moving the box, becuase the front plate couldn't be moved THAT far forward without running the risk of the wires popping out of the box.
If that's the case, that would require an inspection from the town, and therefore a licensed electrician wouldn't it? (I actually wouldn't be averse to hiring an electrician, becuase the bathroom outlet is not a GFCI... It's still the original outlet from way back when.....)
Or is simply moving a closed box forward not considered technically "moving a box"? If it COULD be a DIY, how should I proceed? (Electrical is the LAST place I want to make a mistake!)
thanks for your help
diy'er on LI is offline   Reply With Quote
Old 11-19-2009, 05:28 PM   #2
If it's a " or less you can get a box extender, even at the big box stores. While your jurisdiction may require a permit, no jurisdiction that I know of requires you to hire an electrician. I don't believe moving the box out is considered "a move".
hayewe farm is offline   Reply With Quote
Old 11-19-2009, 05:30 PM   #3
the Musigician
DangerMouse's Avatar
if it were me, i'd cut the power and figure out the best way to move the box forward, then replace the standard outlet with the correct one for the bathroom.
DM
Old 11-19-2009, 05:30 PM   #4
Just use longer screws on the switches/receptacles. The tile's not gonna catch fire
Use a plastic "box extension" if you want to be 100% legal. They slip inside the box and cover the gap.
220/221 is offline   Reply With Quote
Old 11-19-2009, 05:36 PM   #5
long island, NY
ah, a simple solution...
I shall grab a couple box extenders from my favorite big box shop I think this job is even simple enough for me not to screw-up
thanks!
Old 11-19-2009, 06:07 PM   #6
Thumbs up
thanks!
Take 220/221s (poster #4) advice. Best and quickest to do. On the next job always consider (depth) how the box will look after dry wall or tile (the thickness) is added. And when measuring height, always know what the floor or ceiling will add to or reduce from the total height.No matter what. Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-19-2009, 06:11 PM   #7
the Musigician
be sure to swap old outlet for a GFCI if it's in the bathroom.
DM
Old 11-20-2009, 12:41 PM   #8
long island, NY
eh, I'll get the box extender. It doesn't take much more effort, and I'm at lowes or HD every weekend these days anyway.... the tile obviously can't catch fire, but there is a smidge of paper from the drywall that pokes out near the box....
there are actually THREE bathrooms without GFCI outlets... So, on my list of "things to do" is hiring an electrician to replace those, and install a chandelier that's in a very beastly location (about 15 feet above a staircase). But it will have to wait until I obtain the $$$ for that.....
Old 11-20-2009, 04:50 PM   #9
This situation has come up before.
The tile is absolutely fireproof.
IMO, you're safe with no box extender.
Old 11-20-2009, 06:59 PM   #10
Licensed electrician
Rewards Points: 1,788
While there might be little risk, without the box extender it would not be a Code compliant installation.
Old 11-20-2009, 07:32 PM   #11
In that case, I hope the extenders fit. Otherwise, I guess you can get little abrasive wheels to enlarge the tile holes.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
adding outlet from light switch tad Electrical 17 06-05-2009 11:25 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
