Tighten Unused Screws On Receptacle? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 01:13 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Tighten unused screws on receptacle?
Just saw a picture in another thread where the unused screws on a duplex receptacle are left un-tightened. I see this often on pictures posted here and have found it in my own home. Is there a code issue one way or the other? The old timer I learned from insisted on all the unused screws be tightened down. I have always made it a practice to tighten them. I certainly am not a code maven but have never seen a reference either way.
Coastal South Carolina
Old 11-27-2012, 01:19 PM   #2
Licensed electrician
Rewards Points: 1,018
No code rule about this. Like you I always tighten them down. This was more of an issue with metal boxes and the close fit.
rjniles (11-27-2012)
Old 11-27-2012, 02:13 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
The same as Jim, most often found with back stabbed receptacles.
jbfan is online now   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Is it acceptable to use push connectors AND screws on a duplex receptacle? Bob K. Electrical 5 03-07-2010 08:14 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 07:20 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
