Tie Off A Run In Junction Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2008, 10:42 PM   #1
Tie off a run in junction box?
Hello,
I was digging in the flower bed out front today and found a buried wire the hard way, about four inches down. Knicked it just a bit. There's a flared piece of plastic insulation where I was digging, looks like it either is a defect in the insulation or maybe I knicked the wire. Hard to tell. I can't see copper, but I stuck a compact mirror underneath the cable and there's what might be dirt, might be exposed wire down there -- leaning towards dirt. Wrapped it with some electrical tape for now.
Now, the funny thing is, that wire doesn't go anywhere. When I first moved in there was a reference to a post lite on the electrical panel. I've since had the panel replaced and I don't know what breaker that was. I am assuming this wire goes to wherever that post used to be.
Traced it inside the house and it leads to a junction box in my crawlspace. No clue what is between the junction box and the panel, the wire leads up and could go anywhere. There is a lightswitch in the living room, just above the crawlspace, that does not appear to do anything -- I'm guessing this is the switch to my non-existent post lite.
Two questions:
1) Is there a safe way to repair that little knick (silicon, maybe) and forget about it?
2) Or should I just go to the junction box, disconnect the outgoing cable, and put nuts/electrical tape on the incoming wire. Is this safe to do?
Dave
NotSoHandyman is offline   Reply With Quote
Old 05-24-2008, 11:10 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
If you are sure that you will never use the wire, then disconnecting at the j-box is a good idea.
Old 05-24-2008, 11:24 PM   #3
Pretty sure. Worst case I can always reconnect it. I wasn't sure leaving hot wires nutted off in the box was OK or not.
Old 05-25-2008, 09:36 AM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
No problem with that.
John
jrclen is offline   Reply With Quote
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
Range & Junction Box Distance G3Aloha Electrical 1 05-10-2008 01:13 PM
Junction Question? fw2007 Electrical 10 03-31-2008 12:03 PM
Device Box used as Junction Box BigJimmy Electrical 5 01-27-2008 10:37 PM
Old House - no junction box - HELP! Designman20 Electrical 22 10-11-2007 05:58 PM
