Thru Wall Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 02:28 PM   #1
Thru wall connection
My new home has a built in, corner, entertainment center. It has electrical, cable, and phone connections. On the other side of the wall is the location of where I will hang my TV in a bedroom.
Is it considered acceptable/code to install some type of thru the wall "hole/box" to run electrical cord and cable TV coaxial from wall hung bedroom TV, thru the wall, and plug all in at entertainment center?
I know how to do so. That part is a no brainer but acceptable/code is the question.
Hope I have explained this all.
john curry is offline   Reply With Quote
Old 01-19-2011, 05:39 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
You can run a coaxial line through the wall. The power cannot be run that way. You must install a new box with a new receptacle in the bedroom. Depending on which code cycle you're on, the receptacle may be required to be AFCI protected.
iminaquagmire is offline   Reply With Quote
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
