Throwing Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 12:33 PM   #1
Throwing breakers
I've got a fith wheel travel trailer. It runs 110v at 30 or 50 amp. 50amp actually has 2 hot lines, but 1 of them is for the second air conditoner only, if you have one and I don't. My problem is I keep blowing the air conditioner circuit. Also when it goes the one just below it goes too. It would seem that somebody routed most everything through 1 breaker. I know the air, microwave, coffee maker and light/ceiling fan are all on 1 circuit. Why would a 110 airconditoner blow 2 breakers? Also, plugging into 50amp usually stops this issue. Why? It's only a 110 air conditioner and there is no second air conditioner and I'm not blowing the breaker out on the pole it's on the inside. I think I'll go in and try to break things up a bit but can I have a bad breaker? Would that make it blow all of the time or is it a when it goes it goes kind of thing?
MMeyerssr is offline   Reply With Quote
breakers compatible with panel--HD says... Daneel Electrical 6 06-10-2011 06:31 PM
Re-Certified, Re-Furbished Circuit Breakers i_need_help Electrical 5 02-10-2011 07:23 PM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 01:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
