Through The Joist Into The Canister, Staple? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 11:08 AM   #1
Rewards Points: 77
Through the joist into the canister, staple?
I am running my cable from the joist into the circled knock out on this canister light. I know I am supposed to staple within 12 inches of the knock out. How should I do it here? If I staple it I am going to have to almost bend it at a 90 degree angle, then staple, then bend again. It would be a lot smoother just curving it right into the knock out. I have a few lights with this scenario. Should I run the cable in through a different route? I could, but it would waste a lot more cable, but I guess it would solve the problem.
epeterson777 is offline   Reply With Quote
Old 02-08-2009, 11:18 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It may sound a bit cheesy but what prevents you from placing the staple IN the hole?
If you don;t like that, attach a piece of 2x4 onto the joist so the cable will run across it as it exits the hole and place your staple there.
Old 02-08-2009, 11:22 AM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Take a wire tie and tie it to that cross member.
wirenut1110 is offline   Reply With Quote
Old 02-08-2009, 11:45 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Good suggestion, NEC 300.11 says you cannot wire tie to a wireway e.g. a conduit, but there is NO prohibition against using a wire tie to mechanicals.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-08-2009, 12:03 PM   #5
nap
You talking to me?
nap's Avatar
You guys get away with using wire ties (zip ties) on NM? Boy, the inspectors are sure different here. I don;t do resi for a living so I don;t concern myself too much with resi specific code but I know of inspectors that would not allow such.
Old 02-08-2009, 12:04 PM   #6
Just staple it to the joist.
The little extra loop of wire is coverd by drywall...right?
And....the jbox on the can has built in connecters so you don't have to use the KO and a connector. Pry out the little ko's, strip and push in your cable(s).
220/221 is offline   Reply With Quote
Old 02-08-2009, 12:12 PM   #7
Rewards Points: 510
MC cable too
Old 02-08-2009, 12:15 PM   #8
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
I have to to look it up but I think you're alright without using a staple because the bored hole is within 12" of the box for the recessed light.
Magnettica is offline   Reply With Quote
Old 02-08-2009, 12:34 PM   #9
nap
You talking to me?
nap's Avatar
but doesn't the NM have to be attached within 12 inches?
wirenut: we get to use zippies on MC and AC. It seems the inspectors for resi have a problem with NM though. Maybe it has to do with guys yanking them real tight. Not sure though.
Old 02-08-2009, 01:25 PM   #10
Electrician
Why on earth would it not be allowed?
chris75 is offline   Reply With Quote
Old 02-08-2009, 01:26 PM   #11
Electrician
There is no such thing as a Resi code.
Old 02-08-2009, 08:34 PM   #12
nap
You talking to me?
nap's Avatar
I said resi specific code and there most certainly is.
recep placement (12 foot rule); kitchen requirements; either overhead switched light outlet or switched wall outlet; etc.
those are all resi specific codes and I do not deal with them since I do not do residential work.
and why a zip tie may not be allowed is an installer could have a tendency to tighten the thing down and cut into the insulation just as when nailing down a staple too tight. That is one reason one of the counties in my area requires plastic w/nail cable fasteners rather than staples. It is harder to make them "too tight".
I can yank a zip tie pretty tight, especially when using a tightening tool. I could damage the NM by doing so. Of course, if doing things properly, it is not a concern but there are many situations where code specifies the obvious.
those are all resi specific codes.
Old 02-08-2009, 09:06 PM   #13
Sorry to jump off topic but when I moved into my house there was a wire zip tied to a sheet metal duct support, tight against the sharp side. I don't know whether or not zip ties are approved here but some people just have no common sense no matter what they use.
I would bend out of the hole and stable to the joist, then loop to the fixture with a grommet. Is that the only wire going through that big hole?
Reilley is offline   Reply With Quote
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
wire staple removal madmax55555 Electrical 8 07-03-2006 05:29 PM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
