Three Way Timer Install - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 03:33 PM   #1
Three way Timer Install
How can I tell which is the load switch or the line switch?
dldriscoll is offline   Reply With Quote
Old 12-02-2011, 04:10 PM   #2
Rewards Points: 6,652
Line is power, load is exactly that. It can be a light, a device such as a stove, a/c, furnace, etc.
Old 12-02-2011, 06:00 PM   #3
joed's Avatar
Rewards Points: 11,508
Measure voltage from common screw to ground. Flip the switch. If the power goes on and off it is the LOAD switch. If the power stays on always it is the line switch.
NOTE:
THIS HAS TO BE DONE WITH THE POWER ON AND THE SWITCH EXPOSED. IF YOU ARE NOT COMFORTABLE WORKING WITH LIVE POWER THEN CALL SOMEONE WHO IS.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
GE Smart Digital Timer Will Not Work Manually dgbarar Electrical 3 10-31-2010 09:15 PM
Install an electronic timer CaJazzman Electrical 8 08-13-2008 05:12 PM
Timer Installation lpmike82 Electrical 3 06-21-2008 03:58 PM
