Three Way Switches With Two Lights Between - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 01:08 PM   #1
Three way switches with two lights between
Hi Gang,
It's my first post here, but I've been relying on the forums for a few months. Here's my problem: I wired two hall lights with two three way switches as per the diagram. The problem is that a switch will only work when the other switch had last turned the lights on.
Is there something I'm obviously doing wrong? Thanks.
chief44444 is offline   Reply With Quote
Old 03-19-2011, 01:19 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
One of the switches is wired wrong. You have a traveller and the common hooked up wrong. Re-check.
Kyle
Old 03-20-2011, 12:24 PM   #3
That worked! Thank you.
Old 03-20-2011, 06:54 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Just want to give you a head up that figures what The OP posted that diagram is no longer used on 2011 NEC code cycle I know couple states are allready adpoted new NEC code now and which that mean the switch loops are no longer use without netural at all switch boxes.
So for other readers please make a note when you run new three or four ways run the power to first switch then { you will use XX-3 NM cable betweens three or fourway switches } next switch after that you can switch back to XX-2 NM then to the luminaires the reason why need netual due some motion sensors or electronic timers may required netural at the swtich boxes.
Also it make it easier to trouble shooting as well.
We have that standard code in France for last couples years so I got a habit to make sure you have netural in switch boxes.
To OP ., you should be ok as long you are on 2008 or earier NEC code verison.
Merci.
Marc
Old 03-21-2011, 08:25 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Good point. Thanks for the tip.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
frenchelectrican (03-22-2011)
Two Lights, Two Switches Headache darveaux Electrical 13 01-21-2011 12:47 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
Two switches between power and lights HooKooDooKu Electrical 4 04-19-2010 05:14 PM
