Three Way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 11:23 AM   #1
Three way switches
I have a small bathromm (Jack and Jill) that has two switches for the lights. One is a three way switch with the white wires spiced together in the box, two hot wires to the switch, and a red traveler wire to the switch. Seems Right. The other switch is only a two way switch so that it has to be on for the three way switch to work at all. It has one red traveler wire and one hot wire - that is all. Can I attach the hot wire to the COM post on a new three way switch, and put in a jumper from the push-in connector at the COM and jumper to the other pole rather that have someone find a hot wire in the box to splice into?
daledougherty is offline   Reply With Quote
Old 08-16-2010, 01:40 PM   #2
Electrician
Proby's Avatar
Pictures of each box would really help.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-16-2010, 02:21 PM   #3
joed's Avatar
Rewards Points: 13,308
If there are only two wires in the one box you can't make a three way switch work there properly. You will need a new cable or a wireless three way.
Help me ID these switches... jp2code Electrical 15 05-02-2015 08:52 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
