Three Way Switch Wiring Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 01:34 PM   #1
Hi Everybody
We're having a problem with wiring a three way switch. We have a three way switches at the bottom and the top of the stairs that lights a sconce at the bottom. We would like to add another sconce at the top of the stairs to the same configuration. We added a 12-2 wire from the new upper sconce to the upstairs switch. The upstairs switch lights both sconces perfectly. However, the downstairs switch only lights the bottom sconce. Does the fact that we did not have a common or traveler connection to the new upper sconce from the bottom switch or fixture the reason that it's not working? Could someone provide some directions on what we should do next? Thank you very much
See ya soon
Chipper
chipper1 is offline   Reply With Quote
Old 10-18-2010, 02:31 PM   #2
Just call me Andrew
Rewards Points: 1,020
Is the lower sconce wired with 12/2 to the bottom switch?
Both lights need to have a cable to the same switch.
Or, the two lights could have a cable from one to the other.
Do you know where the power comes in from the panel? To one of the switches? To the existing light?
Andrew
secutanudu is offline   Reply With Quote
Old 10-18-2010, 03:16 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
Originally Posted by chipper1 View Post
Hi Everybody
See ya soon
Chipper
You need to wire the upstairs sconce to the downstairs sconce and not touch the switches!
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 05:16 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
