Three Way Switch, Two Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 12:30 PM   #1
Three way switch, two lights
I need to wire a three way switch in this way:
Power-->light1-->light2-->switch--->switch
I found the attached diagram.
Is there a way to do it with two wires between the lights?? Why can't I bring power to light1, carry hot and neutral to light2, and then break the hot at light two and go switch-->switch.
Thanks in advance.
zubor is offline   Reply With Quote
Old 09-24-2012, 12:34 PM   #2
Rewards Points: 1,512
power --> light 1 --> light 2 --> switch 1 --> switch 2
You need one wire between the lights for the neutral to light 2, the second wire to carry the raw power past both lights and down to the switches, and the third wire to bring the switched power back to light 1.
AllanJ is online now   Reply With Quote
Old 09-24-2012, 12:40 PM   #3
Rewards Points: 2,516
What do you mean by two wires between the lights? The diagram shows a 3-conductor cable which has 3 conductors and a ground wire.
Isnt this what the diagram shows??
what do you mean by break the hot at light two and go switch switch?
hammerlane is offline   Reply With Quote
Old 09-24-2012, 01:04 PM   #4
This is what I mean.
Old 09-24-2012, 01:07 PM   #5
Nevermind!!!! I see now that light 1 will never be off! I will leave my stupidity posted for others to learn from. Sorry for the waste of time!
Old 09-24-2012, 01:10 PM   #6
Still do not understand if you know the diagram in your 1st post is correct, why do you need to try and alter it. Do you have a different wiring configuraation where you need to feed something else like a receptacle off the incoming power?
Old 09-24-2012, 02:39 PM   #7
joed's Avatar
Rewards Points: 12,862
Probably because he ran two wire cable between the lights before he found the diagram.
Old 09-24-2012, 02:43 PM   #8
No!!!! It's because there already was 2-wire cable between them and it's a pain to fish
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Double combination switch not turning on lights Mwright1978 Electrical 4 12-31-2011 06:37 PM
2 Wall Lights, 1 Switch twak21 Electrical 5 11-28-2011 06:59 PM
Indoor switch for outdoor motion activated security lights youngdoc Electrical 5 12-02-2010 02:07 PM
Wiring a switch to rope lights DK75 Electrical 5 12-02-2010 07:49 AM
