Old 10-03-2010, 07:12 PM   #1
Three way switch to single?
Hello, I recently bought an old home with several light fixtures missing. I successfully installed one fixture (it came on) then then found that the switch in the room would not turn it off.
Upon opening up the switch I found two white wires capped off with wire nut and two black and one red wire connected loosely to the old switch. This seems to be the configuration for a three way switch but I cannot for the life of me figure out why there would be one in this room. I tried capping off the red and connecting the two black (one hot and one not) to the new single on/off switch and nothing happened. I would love to know how to fix this switch.
Thanks!
idscnyco is offline   Reply With Quote
Old 10-03-2010, 07:20 PM   #2
joed's Avatar
Tell us about the hold switch. Did it have two or three wire connections? Where both blacks connected to the same terminal?
How many wires in the fixture? Was there a red wire? If there was then probably you should have connected the fixture to white and red.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-03-2010, 07:31 PM   #3
The old switch had four push in connections - with two black wires connected on one side and one red on the other.
I just checked and the fixture does have a single red wire which has been taped off and white and black wires of course. I had previously connected white and black to fixture.
THanks joe!
Old 10-03-2010, 11:22 PM   #4
joed's Avatar
I would say the two blacks connect together and to one terminal on the switch. The red connects to the other terminal.
The fixture connects to the whites and the red.
Old 10-04-2010, 07:50 AM   #5
Thanks Joe,
I will try this method - but I don't know what to do with black in ceiling. Should this just be capped off?
Thanks,
Alison
Old 10-04-2010, 02:38 PM   #6
joed's Avatar
There will be one extra wire in the first light that you just cap off. Cap it off in the other junction box where the switch used to be as well. That old switch junction box can not be buried in the wall either. You must leave it accessible with a blank cover plate.
Convert single pole switch to a 3 way! Wildie Electrical 19 05-13-2010 11:20 AM
Need Help Troubleshooting 3-way + Single Pole Switch Install OmegaRed1723 Electrical 6 10-09-2009 11:25 PM
Adding a single pole switch to 3 way switch. adrien2 Electrical 6 05-28-2009 03:44 PM
Help with single pole switch ballutster Electrical 2 10-13-2008 08:57 PM
Three way switch into single switch? kcrossley2 Electrical 11 02-24-2008 08:23 PM
