Three Way Switch To Simple Two Way? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 04:39 PM   #1
Three way switch to simple two way?
Hi - I have a room that has two three way switches, one opposite walls.
I have no need for the switch on the far wall, and want to make the other switch a "regular" light switch.
How should I re-wire the other (the one I DO NOT WANT) so I can do this?
Phil.
Bagpuss1974 is offline   Reply With Quote
Old 10-09-2008, 04:45 PM   #2
Electrician
Phil.
If you have no use it then just dont use it... Seriously, do you plan on removing the switch and patching the wall?
chris75 is offline   Reply With Quote
Old 10-09-2008, 04:54 PM   #3
I was hoping to remove it and drywall over it since it ruins the wall as is (we've redecorated etc.).
Old 10-09-2008, 04:55 PM   #4
Electrician
Your going to have to open the switch you want removed and see whats going on, you cant just bury a box like that. How bout a blank plate painted to your wall color?
Old 10-09-2008, 05:06 PM   #5
Yes. I considered that - and that's why i posted here.
I need to know which wires to connect properly so that the right connection is made....
Old 10-09-2008, 06:36 PM   #6
What you need to do depends on how it's wired.
Whether or not you can bury the box also depends on the wiring.
Take two pics or describe in DETAIL the wires/cables in each box. It is just a matter of a couple wire nuts to rewire it.
220/221 is offline   Reply With Quote
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
Simple wall switch question LZCenter Electrical 8 06-30-2008 11:01 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
simple light switch sedwick Electrical 3 09-25-2006 01:38 PM
