Three-way Switch In The Same Box As Single-pole - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2008, 11:22 PM   #1
Three-way switch in the same box as single-pole
i've got 14-2 wire coming from my service panel into a double gang-box that will contain one single-pole light switch that will control a ceiling light, and the initial 3-way light switch that will power two linked can lights. the second 3-way switch is across the room. how do i jump power from the single pole switch to the 3-way? just as if it were another single pole there? the two can light fixtures are between the two 3-way switches. from the first 3-way switch do i run 14-3 wire to the first can light or to the other 3-way switch? and do i link the can lights with 14-3, 14-2, or 2 14-2s? keep the terms simple, i'm no electrician. thanks all.
phatsajak is offline   Reply With Quote
Old 04-08-2008, 04:54 AM   #2
Bring a 14/3 to the other switch and a 14/2 from either switch to the cans.
Thing to remember on 3-way switches is to hookup the constant hot (black wire) on one common screw and the hot (black wire) going to the light on the other 3-way switch. And tie the white going to the light on the neutral bundle (white from panel).
NAIL is offline   Reply With Quote
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Three way switch into single switch? kcrossley2 Electrical 11 02-24-2008 07:23 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 07:06 PM
