Old 11-16-2008, 06:51 PM   #1
Three way switch questions
Ok, here goes. 14/2 to box one. Box one is two 3-way switches. From each of these switches is a 14/3 to box two. Box two has two 3-ways. From Box two there is a 14/3 going to a fan light combo. Question is, should both groundeds be connected and both boxes. I'm looking at the diagram and something doesn't seem right(multiple return path of the two groundeds between the boxes).
jerryh3 is offline   Reply With Quote
Old 11-16-2008, 06:56 PM   #2
Electrician
That would create a parallel neutral path no? Seems like a violation if you ask me.
chris75 is offline   Reply With Quote
Old 11-16-2008, 07:01 PM   #3
That's what I was thinking. I'll just remove one of the neutral connections between the boxes. Should have only run one 14/3 and a 14/2 between the two boxes.
Old 11-16-2008, 07:02 PM   #4
Electrician
That's what I was thinking. I'll just remove one of the neutral connections between the box. Should have only run one 14/3 and a 14/2 between the two boxes.
I bet that happens alot with out people blinking twice at it. Pretty good catch if you ask me.
Old 11-16-2008, 07:09 PM   #5
I have to go back and look at it again tomorrow. Ran out of time today, and I just wanted to double check about the neutral. This box was a pain. Two three ways and a double switch. I love helping out family.
Tags
switch
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
