Three Way Switch The Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 08:20 PM   #1
Angry
three way switch the lights
I have a dining room fixture with two switches that look like this:
The switch on the left is a dimmer.
The switch on the right also has black & white wires (not currently connected) coming in from the bottom of the box for two wall sconces. I cannot get the wall sconces to work at the same time as the dining room fixture. It's always one or the other.
Does anyone have any suggestions.
pdino is offline   Reply With Quote
Old 06-30-2012, 09:48 PM   #2
Sparky
Rewards Points: 510
you dont have a neutral available at the 'right' switch. you need an xx-4 cable between the dining room fixture and the 'right' switch to make what you want work.
Techy is offline   Reply With Quote
Old 07-07-2012, 06:38 AM   #3
Techy,
Thanks for the reply. Is there a different way to wire this without running new wire? My wife said that she would even prefer having the lights on two separate dimmers.
pdino
Old 07-07-2012, 07:39 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by pdino View Post
Techy,
pdino
You could remake the existing spice and make each switch a single pole.
Old 07-07-2012, 11:30 AM   #5
three way switch
Thanks Stickboy1375.
Any ideas on what the wiring would look like?
pdino
Old 07-07-2012, 11:35 AM   #6
E2 Electrician
pdino
One member here does a great job at doing wiring diagrams, maybe they will chime in, or I'll draw you up something later.
Old 07-07-2012, 11:53 AM   #7
Thank you again!
Old 07-07-2012, 12:42 PM   #8
E2 Electrician
Hopefully this is how your existing dinging room light is wired, if not, just let me know.
Double combination switch not turning on lights Mwright1978 Electrical 4 12-31-2011 07:37 PM
2 Wall Lights, 1 Switch twak21 Electrical 5 11-28-2011 07:59 PM
How to connect 2 lights to a double switch B4rg Electrical 7 05-09-2011 10:18 PM
Indoor switch for outdoor motion activated security lights youngdoc Electrical 5 12-02-2010 03:07 PM
Wiring a switch to rope lights DK75 Electrical 5 12-02-2010 08:49 AM
