Three Way Switch Into Single Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 12:30 PM   #1
Rewards Points: 562
Three way switch into single switch?
I have an outlet in my home that's controlled by two switches. I want to eliminate the second switch, which is unneeded, so I can place a picture over it.
I don't want to remove the switch wiring, just in case I should ever need it again. How can I wire the three way switch on the side I want to cover so that the second switch is still operational?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 02-24-2008, 01:00 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes you can do this. We need to now where the incoming power comes in at. In other words does it come in at one of the 3 way switch boxes or at the receptacle? A description of the wire colors and how they connect in each electrical box would be nice. Be sure to identify the incoming power cable for us.
Only one of the 3-way switches has the switch leg to the receptacle. So we need to know which one that is in order to give you a wiring diagram to show what changes you need to make.
Old 02-24-2008, 01:35 PM   #3
Electrician
When you remove the switch from the location you do not want, splice the point wire to one of the travelers, cap off the other traveler and install a blank plate... then check your work.
chris75 is offline   Reply With Quote
Old 02-24-2008, 04:22 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Chris
You talking to a home owner ......point wire?
Old 02-24-2008, 05:07 PM   #5
Electrician
Originally Posted by Stubbie View Post
Chris
What do you want from me? besides its three wires, there odds are pretty good they get it right...
And reread your post and tell me a homeowner will understand it..
Old 02-24-2008, 05:13 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Yes, my apologies. But there may be more than three wires.....just not connected to the switch.
My posts are always crystal clear .......
Old 02-24-2008, 05:18 PM   #7
Electrician
I know i'm not always so good at keeping it simple.... Thats why your here
Old 02-24-2008, 05:24 PM   #8
Simple.
Remove the switch you want to remove.
One of the wires goes to a terminal marked "common".
Cut, strip and connect this wire with ONE of the other wires on the switch. Cap the remaining wire.
Your other switch will now function as a single switch.
If it's upside down (on= down), go back take the wires apart and attach the other wire to the common at the first box
It doesn't matter which end. Both switches simply connect the common (hot or sw leg) to one of the travelers. Hardwiring the common to a traveler in either end will do the trick. The only question will be the on/off position of the other switch.
220/221 is offline   Reply With Quote
Old 02-24-2008, 05:34 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Yes I must agree. My original thought was for him to convert to a single pole at the other end but Chris posted a much easier fix.
Old 02-24-2008, 05:38 PM   #10
Electrician
Yeah, but 220/221 cleaned up the whole mess...
Old 02-24-2008, 05:46 PM   #11
First you will need a tester, a box of Kleenex, four tangerines and some kitty litter.................
Old 02-24-2008, 07:23 PM   #12
UAW SKILLED TRADES
Stubbie's Avatar
By my count Chris fixed the problem with 3 lines of text.
220/221 fixed it in 3 lines also but confused the issue with something about up and down therefore I'm penalizing him 2 lines of text, making it 5 lines total. He did fix it though.
And then there was the other guy who neither came up with a fix nor limited his lines of text. He did however include a much more educational method which would have led to a better understanding of what was going on in the users electrical boxes plus the OP would have also had a nice shiny new switch with an 'on' and 'off' for good measure.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 12:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 10:10 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 07:06 PM
