Three Way Switch I Can't Figure Our For The Life Of Me - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 07:39 PM   #31
Originally Posted by jrclen View Post
You could start trouble shooting the circuit with your volt meter / ohm meter. Start with the switch where the source power is located. Work your way to the 2nd switch and then on to the light. Also check to see if the white wire at the light fixture actually provides a path back to the electric panel neutral bar.
I uncapped the white and checked voltage to the circuit and got 120. Then checked every breaker voltage and got 120.breaker ought to be good.
S65b40 is offline   Reply With Quote
Old 09-10-2012, 07:40 PM   #32
Originally Posted by Gac66610 View Post
Well, how many lights? Could it be bad light bulbs? Just throwing stuff out there.
Maybe thats been suggested.
I thought that too. Then I changed the bulbs and no luck.
Old 09-10-2012, 08:16 PM   #33
Resi EC
Rewards Points: 252
Well beans, where you at, jumpin in van now ... lol ... well, not really
Gac66610 is offline   Reply With Quote
Old 09-11-2012, 08:36 AM   #34
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You checked the white in the light fixture with a known hot wire and got 120? That's a good start. And you checked the common at switch one and got 120? And then you checked the common of switch two and and got 120 after turning the switch on? And then you checked the hot at the fixture and got 120 after turning the switch on? If so, the circuit is good.
John
jrclen is offline   Reply With Quote
Old 09-14-2012, 02:06 PM   #35
any other ideas on this? im going to tackle it again this weekend...not looking forward to it..thanks
BTW, theres a Fan with 2 switches, light and fan, next to the this light switch...do you think they are somehow related?
i did wire the fan and light correctly so i dont know...the ceiling fan is in between the 2 lights in the ceiling that im having issues with
Old 09-14-2012, 04:09 PM   #36
jrclen's Avatar
Rewards Points: 514
Stabbing at it is not getting you anywhere. You need to do it like an electrician. Trouble shoot the circuit, start to finish with a volt/ohm meter. See my previous post. If you called a professional, he would methodically trouble shoot the circuit and find the problem in less than an hour. Most likely way less.
John
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
