Three Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 11:17 AM   #1
I am trying to replace a set of three way switches. I am trying to add z-wave switches. I purchased: GE 45613 Z-Wave Technology 3-Way Dimmer Switch Kit
See instructions
The originally three way switches have three wires attached. Two blacks and one reds. After figuring out that I need a neutral wire I gave up. Then I looked in the boxes and there are white wires that are all spliced together. One switch box has 2 wires and the other has four white wires. Are these the neutrals? why are they all spliced together?
Any help you can provide would be greatly appreciated. I do not have a voltage meter but I can gout and get one if needed.
Thanks in advance
rcreff is offline   Reply With Quote
Old 02-26-2012, 11:32 AM   #2
Rewards Points: 2,516
Odds are the whites are neutrals since the original 3-ways had other blacks and reds connected to them.
They are all spliced together, I assume with the use of a wire nut, because that is how continuity is achieved.
A couple pictures posted of the wiring inside the switch boxes would not hurt.
hammerlane is offline   Reply With Quote
Old 02-26-2012, 11:34 AM   #3
Neutral???
So, do I take the neutral from the switch and wire it to the white wire's wire nut? Are all the neutrals in the house tied in together? Sorry...just trying to understand how the neutral works. The switch has the following connections:
Traveler
Line
Load
Neutral
The other switch is:
Traveler
Neutral
Thanks,
Rob
Old 02-26-2012, 11:49 AM   #4
Traveler
Line
Load
Neutral
Traveler
Neutral
Thanks,
Rob
Yes, just connect the white from your switch to the neutrals already connected together in the wire nut.
For your first switch, the black is the line, blue is the load, yellow is the traveler. For your auxiliary switch, the yellow is the traveler and white/red is your hot.
hawkeye11 is offline   Reply With Quote
Tags
lighting , switch , z-wave
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
