Three Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 07:36 PM   #1
Three Way switch
Does anyone have a diagram for a three way switch that operates two lights? The thing is I'm looking to jump from each switch to a light. It's a staircase surrounded by 2x12 joists (not easy drilling). I have the 3 wire in place , and it would be much easier if I didn't have to jump from light to light.
Thanks in advance
Jim
Jim64conv is offline   Reply With Quote
Old 09-05-2008, 07:46 PM   #2
Between the switches?
If you feed the lights individually from the two switch boxes you will need an extra wire between the sw boxes.
Basically, power at one end, switch leg(s) at the other end with a 3 wire between them.
220/221 is offline   Reply With Quote
Old 09-05-2008, 08:14 PM   #3
Electrician
Here is a diagram I like to use when involved with stairs and such... see if it makes sense to you...
All i'm doing is running a 3 conductor from a switch to a light then a 4 conductor to the next switch then a 2 wire to the next light.
chris75 is offline   Reply With Quote
Old 09-05-2008, 08:18 PM   #4
OK, what I have in between the switches is AC BX 12/3 with ground, so there are 4 wires. Can I make this work? Can it pass inspection? This is a brand new house getting rough inspect next week.
Old 09-05-2008, 08:28 PM   #5
Electrician
12-3 is not the same as 12-4. and no it wont work...
Old 09-05-2008, 08:30 PM   #6
Thanks Chris, was still trying to make sense of your sketch
Old 09-05-2008, 08:31 PM   #7
So basically I'll have to jump from light to light then?
Old 09-05-2008, 08:32 PM   #8
Electrician
You got it!
Old 09-05-2008, 10:35 PM   #9
Electrician
SD515's Avatar
Rewards Points: 504
Or both light runs have to leave the same box.
Old 09-06-2008, 03:21 AM   #10
Me too
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
