Three Way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 12:42 PM   #1
Three way switch
This has been driving me crazy. I have a three way switch in one room powering two three way switches and one light switch in another room. The problem is I need to power my outlet from the box that is powered by the three switch in the other room that has the load. This is what happens when I use the three way it closes the load at one switch while the other is hot. So i cant find a steady load in the box i need to power my outlet. Basically how to power a outlet from a three way switch, is this possible. I can't figure it out.
Tomas813 is offline   Reply With Quote
Old 03-06-2013, 01:02 PM   #2
Rewards Points: 2,516
Your description is a bit confusing especially:
I have a three way switch in one room powering two three way switches and one light switch in another room. .
The diagram below shows a receptacle being powered from the same location as the 3-way switch not the recepatcle being powere3d BY the 3-way switch.
If you have 3 switches able to control one load, then one of those switches are most likely a 4-way switch.
hammerlane is offline   Reply With Quote
Old 03-06-2013, 03:17 PM   #3
joed's Avatar
Rewards Points: 12,028
It is most likely the you can not do it. There is either no neutral wire or no unswithced hot wire in the box. If you tell us all the wires and how they are connected we can confirm this for you.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 06:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
