Three-way Light Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 01:26 PM   #1
Rewards Points: 332
Question
Three-way light switch problem
I have an issue with a three way circuit for a light in my down stairs hallway.
I have a three way switch for this light which appears to be setup correctly but when turned on trips the breaker.
Near the light itself is a new single pole switch (which I believe should be a three way switch), from some previous upgrade, which works fine and activates the light.
What I need to know is what is the best way to identify the traveler and common wires in this circuit to get this circuit wired correctly again?
tripower is offline   Reply With Quote
Old 01-08-2011, 01:52 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
how much understanding do you have of circuitry and do you have a multimeter?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-08-2011, 02:22 PM   #3
Rewards Points: 332
I have a very good understanding and yes I have a multimeter along with all of the other appropriate tools.
Old 01-08-2011, 02:37 PM   #4
Scared Electrician
Disconnect all wires from switches. In one box there will be a constant hot from the panel. Make all measurements to ground. This should be a black. This constant hot will be landed on the black common screw of the switch. The other two wires(usually white and red) will be your travelers. (white should be marked to indicate that it is a traveler) in other switch box the two travelers can be landed on brass screws, and the other wire is your switch leg which should be landed on the black screw.
http://www.homeimprovementweb.com/in...way-switch.htm
this link has lots of pictures if they help you.
Old 01-08-2011, 04:16 PM   #5
joed's Avatar
Rewards Points: 11,588
Tell us all the wires in both switch boxes and the fixture.
Old 01-08-2011, 07:03 PM   #6
Rewards Points: 332
Question
I appreciate the help. Just to re-cap. You are saying:
1. Power off the circuit
2. Disconnect all wires from the switches (and the light I am assuming)
3. Power on the circuit with the switch wires 'hanging'
4. Test for power
Now with the wires in the circuit that I am working with there is no red (as you would normally see in a typical 3 wire circuit) and the white traveler is not appropriately marked I believe. I am confident that I can quickly identify the originating hot (black) at the 3-way. What I really needed to identify were the appropriate wires at the single pole (that should be a three way).
My initial thoughts was to power down everything then run a continuity signal test so that I could identify which wires were which. Why wouldn't I perform this test?
Old 01-08-2011, 08:33 PM   #7
joed's Avatar
Start here.
Old 01-08-2011, 08:34 PM   #8
Scared Electrician
4. Test for power
more or less
No red, this concerns me as it may not be wired correctly.
This is another good way of determining where wires go to and from. Go ahead and it is probably safer.
Old 01-15-2011, 08:34 AM   #9
Rewards Points: 332
Exclamation
more or less
I just got around to tackling this issue. I am going to open up the boxes, power down and perform a signal test. And try to take some pics if that will help.
Old 01-15-2011, 10:56 AM   #10
Rewards Points: 1,418
Did you just install it or did it suddently trip the breaker when it never used to?
Did you just change a light bulb? Maybe one of the light fixtures shorted out.
Put labels on all wires that you take apart so you know how it used to be connected.
Old 01-15-2011, 11:07 AM   #11
Rewards Points: 332
Got it fixed guys I appreciate all the help. It really didn't take that long once I did a signal test and identified all of the wires. Thanks again.
Light Switch Problem duityourself Electrical 5 07-11-2010 08:42 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 05:00 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
double switch problem jim70 Electrical 5 05-02-2008 08:55 AM
