Three-way Dimmer With Two Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2008, 10:34 AM   #1
I tried installing a dimmer on a three-way circuit that controls two lighting fixtures yesterday. When I flipped the power back on and tested the installation, only one of the two fixtures was dimming. I thought maybe I had misidentified the common wire, so i shut everything down and and switched the wires - but the same thing still happened.
Anyone know why this might be happening? Could this lighting circuit possible be wired wrong?
I'm only good enough with the electrical DIY stuff to trust myself not to get electricuted or burn the house down. Beyond that, I'm quite the novice...
jakerbug is offline   Reply With Quote
Old 07-01-2008, 11:57 AM   #2
Rewards Points: 78
You did use a three way dimmer right?
Did this three way work before? If it did and all you did was replace a switch I would double check and make sure everything is connected as it was before.
Your Quote; "I tried installing a dimmer on a three-way circuit that controls two lighting fixtures yesterday".
Could you be a bit more specific. Look at your statement above. Can you see why I am a bit confused?
Old 07-01-2008, 12:02 PM   #3
yes - it was a three way dimmer. two black wires on one side and a white one on the other. I hooked it up exactly the same way as the old switch. and like i said, i even switched the two black ones, thinking that I might have used the wrong one as the "common" but it did exactly the same thing both ways...
Old 07-01-2008, 11:17 PM   #4
liscenced electrician
Rewards Points: 538
you don't have compact flouresent bulbs in the one that won't dim do you?
jimmy21 is offline   Reply With Quote
Old 07-02-2008, 06:33 AM   #5
Ah ha! Yes I do... I didn't even think of that. That'll do it, huh?
Old 07-02-2008, 01:13 PM   #6
Rewards Points: 78
Now that was fast thinking jimmy. Good job.
Installing Dimmer for fireplace blower MountainMan HVAC 4 07-03-2008 12:09 AM
Dimmer not working (much at all) Gusaroo Electrical 8 03-25-2008 03:45 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
