Three-way Or Dimmer? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 08:01 AM   #1
Three-way or dimmer?
Hello,
I recently purchased an old house that is missing several overhead light fixtures. I am working on a ceiling box with two white, two black, and a single red wire. The wall switch box has the same configuration. I tried ignoring the red wire and the light worked but could not be turned off with the switch. (photos attached, also the old switch)
I am pretty sure that this is not a three-way because there are no other switches in the area. Could this be a dimmer switch configuration?
I would love to know how to wire my light for a regular on/off switch.
Thank you!
Three-way or dimmer?-img_7398.jpg   Three-way or dimmer?-img_7388.jpg   Three-way or dimmer?-img_7395.jpg
idscnyco is offline   Reply With Quote
Old 10-06-2010, 08:36 AM   #2
joed's Avatar
Rewards Points: 12,388
Does the switch control anything? receptacle? other light?
I suspect what you need to do is connect the light to the red and white. Connect the blacks together at the light.
Connect the blacks together at the switch with a pigtail and connect the pigtail to one terminal of the switch. Connect the red to other switch terminal.
Old 10-06-2010, 09:23 AM   #3
It worked!!
It worked!! Thanks so much Joe!!
4 way dimmer jamiedolan Electrical 7 08-24-2010 12:45 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
