Three Switched Lights Trip CB. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 10:18 PM   #1
Three switched lights trip CB.
I have two kitchen lights controlled by two three way switches. The CB trips on this circuit. I thought we had a bad CB but the new CB also trips. I noticed one of the two lights was on before the new CB tripped. No work has been done on this circuit for many years. Any ideas what might be causing the CB to trip?
Taylordump is offline   Reply With Quote
Old 07-24-2010, 11:11 PM   #2
Rewards Points: 1,418
Insulation may have biodegraded or become brittle due to light bulb heat, and flaked off the wire. Then the wire touched something it was not supposed to touch and a short resulted.
You will have to find where any problem might be, it could be in an outlet box other than where the light in question is or where the swithces controlling the light are.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Rewiring a switched receptacle to recessed lights b-boy Electrical 4 03-03-2007 08:01 PM
