Three Prong Outlet On A Non-grounded Circuit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 01:11 PM   #16
Electrical Enthusiast
Rewards Points: 504
Ungrounded outlets inherently are not a fire hazard. Problem is, when they get old and worn out, like most receptacles, they can become a fire hazard due to arcing and heat. The only reason an ungrounded receptacle may be more prone to this is because it is more likely to be old or worn out.
Easy enough?
Kyle_in_rure is offline   Reply With Quote
Old 07-07-2013, 01:36 PM   #17
MarginallyQualified
Rewards Points: 2,464
Originally Posted by gregzoll View Post
Outlet is old, and when you plug something in it, it is so loose, that the homeowner/renter ends up either taping the plug into the outlet, or leaving it as is.
What does that have to do with the outlet only having two slots?
If it's faulty... replace it.
The table lamps and alarm clocks cell phone chargers and desktop radios and such that get plugged into 90% of resi receptacles don't care whether there's an unused 3rd slot or not. Heck most of them don't even care if the outlet is polarized. They don't need it.
Old 07-07-2013, 02:37 PM   #18
MarginallyQualified
again, looks like you need to be given the map showing you the point.
Not at all.
I get that you mean well...but like in the other thread with the "time bomb" warning that guy is far more likely to have a problem from incompetent hands opening and closing boxes and poking around in there than from what was there before he was advised to "check" for something he isn't likely to recognize anyway just for the sake of it.
if it ain't broke don't fix it.
if there is an actual issue... deal. if not? sit on your hands.
If the problem found is of a general nature... then, sure go deeper. But to do so blindly? More likely to create problems than to solve them.
Getting it?
From the other end... is it advisable to update older WIRING so that grounded devices can be used? You betcha. If/when you're doing some other work that warrants the bother and mess... do that work too.
Until then? Deal with what issues you actually have.
In this case the issue is power for a window shaker (or two).
Other threads are about Kitchen or Bath GFI's.
In *those* case? Add those higher draw circuits
The rest? You really can "let it be".
Old 07-07-2013, 04:45 PM   #19
An old Tradesmen
Rewards Points: 7,370
A thread clean up has taken place.
How do I attach a 4 prong cord to 3 prong outlet? jbinnj Electrical 16 03-02-2013 11:41 PM
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
3 PRONG vs. 4 PRONG OVEN OUTLET? Casey_Oakland Electrical 17 05-21-2009 08:26 PM
