Three Prong 15 Amp Recepticals - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 11:59 PM   #1
three prong 15 amp recepticals
I have four recepticals at the end of a run that throws out sparks when you try to plug a three prong plug in with a load on it. Any ideas what may be causing this?
nails33 is offline   Reply With Quote
Old 03-30-2010, 12:06 AM   #2
" Euro " electrician
frenchelectrican's Avatar
there are few ways it can cause the sparks .,,
Loose connection
worn out receptales { simauir to loose connections }
plug in high load devices like toaster or vacumm cleaner or other items.
those three is most common curpits
What kind of load ya talking about ??
Merci,Marc
Old 03-30-2010, 09:23 AM   #3
joed's Avatar
Rewards Points: 13,354
Where are the sparks coming from?
If it is just the prongs then small sparks are normal when plugging a high amp load.
If the sparks are from inside the receptacle then there is likely a loose connection or bad receptacle.
Old 03-30-2010, 09:39 AM   #4
Loose connection
Merci,Marc
It only happens when you plug anything in with the third prong on it. It makes a buzzing sound, like its trying to weld itself to the receptical. The device trying to plug in is a surge protector with TV, sat. reciever. Thank you for your info.
Old 03-30-2010, 10:33 AM   #5
Rewards Points: 506
Short circuit? Does it trip a breaker?
jlmran is offline   Reply With Quote
Old 03-30-2010, 02:54 PM   #6
Electrician
Rudeboy's Avatar
Nails: Don't continue doing that. In fact, I wouldn't be using that receptacle at all. You could be damaging your wires more and more each time or even worse, you could start a fire.
If you feel comfortable changing it out for a new one and/or inspecting the wiring contained within the box, go for it. Otherwise, find someone with some experience to troubleshoot it.
The fact that's it not tripping a breaker could be cause for concern. How old is the wiring in your house?
and...
Read what French said.
Rudeboy is offline   Reply With Quote
Old 03-30-2010, 08:34 PM   #7
I will suggest that get diffrent surge protection strip I think the one ya have is pretty much done for it due majorty of surge will shunt from line to ground ditto with netrual to ground and make sure the surge protection strip master switch is off first when ya plug it in so that way it will not short out itself or do some damage.
I have see few surge protectors get damaged some will show no damage and some will show major damage.
And get a test light to verify the correct sequnece on the receptale the narrow slot is hot while wider slot is netural so run the test light if that lit up between the two that fine now next step is test light from wide slot { netural } to ground slot { it will be flat D shape or a round hole one of the two } it should NOT lit up at all if lit up just hold on that part I will go next step in a second now for narrow slot { hot } run the test light from narrow slot to ground it will lit up if not then you have reversed connection.
It will work the same way with voltmeter but I am not too crazy to use the digtail due it can pick up ghost voltage or inducted voltage.
or buy a simple three lamp plug tester many big box store or hardware store will stock this item and it will only be few Euros { Dollars }
Let us know if you run into more issue with this set up one of us will steer ya in correct way.
Merci,Marc
4 prong 220v recep. to a 3 prong mopowers Electrical 12 05-03-2012 06:39 PM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 06:39 AM
