-   -   Three pole motor control (http://www.diychatroom.com/f18/three-pole-motor-control-151955/)
ryan50hrl 07-29-2012 10:48 PM
Ok, so i'm going to wire my dust collector to a switched outlet for turning it on and off.....I found a leviton heavy duty 20 amp wall switch at home depot that said its rated for motor control.....but the more I got thinking, the more i'd like to do it as a three way so I can turn it on and off from both sides of the shop. However, I can't find a three way that says for motor control on it. I'm finding plenty of heavy duty ones that look the same, but just list fixtures on them, not motors. Do they exist? And if so, are they going to break the bank? The two way is only 5 bucks......
electures 07-29-2012 10:55 PM
Use standard 3 way switches and a contactor.
ryan50hrl 07-29-2012 10:59 PM
Ok, i'm looking at the delta 1.5 hp dust collector and it'll be running on 120V, this switch is the three pole version of the one I bought.....but it lists only 1 hp as the max in the tech specs.......but its a 20 amp switch, and the dust collector only draws 15 amps.....
HELP....i'm confused
stickboy1375 07-29-2012 11:03 PM
12 Attachment(s)
Read post #2....
electures 07-29-2012 11:04 PM
Switch has to be horsepower rated. Your probabely going to need a motor starter and control it with two 3 way switches.
frenchelectrican 07-30-2012 02:06 AM
Ryan.,
The best answer to slove your issue is use the common three way switch and a motour starter contractor that is the best methold to use and I have done that few time in couple customer location so it have a very good result with it.
The other reason why few of us mention motour contractor due some of the dust collector some of them their motour do not have any overload protection so that is the other reason why I used them.
The other reason why I do this is keep the voltage drop to the minum so when the motour start up it don't drop the voltage very much during start up and during running mode as well.
The nice thing with this set up the three way switch will last a long time due you will only switching the contractor load not the motour load so that is one of few big plus.
Just try to see what the 30 amp three way switch cost ( they are CV rated ) but the cost will useally get ya so a common 3 way switch plus contractor is genrally cheaper than use 30 amp three way plus 12 gauge or 10 gauge conductor depending on the run so it will add up fast.
Merci,
Marc
ryan50hrl 07-30-2012 11:46 AM
Maybe I'll stick to a simple two pole.....I think the other options are above my expertise
