Three Outlets Not Working, Wrong Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 06:16 PM   #1
Three outlets not working, wrong wiring?
I have three outlet all in the same vacinity that have never worked. Finally decided to check them out today. Two outlets have one B/W pair running to them but the white is run to the top and the black is run to the bottom of the back of the receptacle. The third outlet has three B/W pairs. Two whites run to the top and one runs to the bottom. Then one black runs to top and two blacks on bottom. Pictures are below. I am not accustomed as a DIY as to this wiring configuration. I just know none of the three outlets work. Could be wired rights but does not look so to me. House is 25 years old. Not sure which circuit they are on in the house and not sure how to figure that out because I cannot get a voltage reading out of the outlet and dont want to disconnect a potentially live wired outlet that might be wired wrong. Voltage out of all three outlets measured by sticking probes into outlets reads zero.
trek508 is offline   Reply With Quote
Old 01-14-2012, 06:33 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by trek508 View Post
I have three outlet all in the same vicinity that have never worked.
Two outlets have one B/W pair running to them...
but the white is run to one side
and the black is run to the other side of the receptacle.
I misread your statements... and edited them.
(only thing worse than no pics is too big pics)
With the probes of a VOM...
someone can investigate more specifically to learn if any of them is hot and where they are from etc.
Someone should. Soon.
Or as jb said: Look at the last working receptacle in the area and check the connections.
Old 01-14-2012, 07:40 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Nothing wrong with the wiring.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
TarheelTerp (01-14-2012)
Old 01-14-2012, 08:04 PM   #4
joed's Avatar
Rewards Points: 12,874
Nothing wrong with wiring but using the push in connections is often a source of this problem. You be well advised to move all the connections to the screw terminals.
Old 01-14-2012, 08:58 PM   #5
Thanks all. This will get me started. Wasn't used to this configuration.
Old 01-14-2012, 09:06 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
The receptacles are wired correctly. Based n the tile it looks like a bathroom. I would look for a tripped GFCI receptacle. In a 25 year old house there may be only 1 and the other receptacles are wired on the load side.
Coastal South Carolina
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 10:31 AM
wiring a ceiling light that branches off to outlets What have I done Electrical 7 08-11-2009 08:24 PM
some outlets not working Clallen Electrical 5 06-08-2009 04:09 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 09:19 PM
