Three Lights One Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 10:50 PM   #1
three lights one light switch
I have three lights the first light has the power source. I would like to install a switch to controll all the lights at once. What is happening now is the light i put the swith wires to works ok but the next two lighs in the string stays on all the time
Handyman1946 is offline   Reply With Quote
Old 03-05-2012, 05:44 AM   #2
Just call me Andrew
Rewards Points: 1,020
How were the lights wired before you started?
Were there switches for each light?
Andrew
secutanudu is offline   Reply With Quote
Old 03-05-2012, 05:44 AM   #3
Rewards Points: 2,516
You most likely have the two distant lights hooked up to the always HOT wire. Make sure you hook up all lights to the switch leg from the switch. If you are using 2-conductor cable w/ground to feed the switch, you use the white wire of the 2-conductor cable w/ground as the HOt to the switch. Just tape both ends of the white wire with black tape to indicate it is a HOT conductor.
Possibly run 3-conductor cable w/ground to the switch. Use the black and reds hooked up to the switch and leave the white capped off. This way you have a neutral at the switch box if needed.
In crude diagram below I did not show any ground wires.
The 2nd photo shows a junction box with the white wire taped black.
three lights one light switch-control-multiple-lites.jpg   three lights one light switch-p_scw_208_11.jpg
hammerlane is offline   Reply With Quote
Old 03-05-2012, 05:59 AM   #4
Below shows how to use a 3 conductor cable to have a neutral at the switch box. Again no grounds are shown.
Old 03-05-2012, 06:56 AM   #5
Rewards Points: 1,512
I noticed that in one of the preceding pictures two wires going to a switch were white.
While that may still occur properly, I would interrupt to remind us that the wire carrying the switched power up to the lights may not be white. Choose one of the other roles to be played with a white wire if there aren't enough colored wires.
Some electricians suggest, for 3 way switches (not the topic of this thread) that the unswitched hot be sent, via the white wire if needed, to the farthest switch box.
Old 03-05-2012, 07:08 AM   #6
DO not understand the queens english or what you mean by
"While that may still occur properly"
Anyway I took the photo down of the 3-way and put up a junction box with a switch loop in it showing white taped black.
good call
Old 03-05-2012, 08:26 AM   #7
joed's Avatar
Rewards Points: 12,854
This is what I think was attempted. It is not to code if a neutral is required in the switch box in your region.
Old 03-05-2012, 10:06 AM   #8
This was the original photo in my post #3 that Alan was commenting on in his post.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 02:48 PM
4 Way Switch controlling 3 lights natenum Electrical 3 09-28-2011 07:46 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
adding second light from a switch agsurfer Electrical 3 09-10-2010 12:01 PM
