Three Light Fixture Only One Light Works - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 12:02 PM   #1
Three light fixture only one light works
Quickly after moving into my newly built home my bathroom light fixture (2 lights) stopped working well, only one light would stay on consistently. We changed out the fixture with at three light fixture. At first, all lights worked correctly, now only one works. Interestingly, the same light worked on the previous fixture. Any ideas?
jenwoode is offline   Reply With Quote
Old 09-21-2010, 12:08 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I know it sounds simple but have you installed known good lamps (bulbs)?
On the new fixture, did you have 3 sets of leads (in the fixture) to connect or was there only 1 with the connection to the other lamps elsewhere within the fixture?
Basically, make sure all connections are good (be sure power is off first). If you are handy, you might try to remove a lamp socket to be sure the connections there are tight.
then, do you have anything to check voltage with? We can walk through some checks if you do but depending on what type of tester/meter you have, there are a few different checks.
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-24-2010 11:38 PM
New outside fixture; light flickers chev Electrical 16 03-26-2009 09:09 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
