Old 06-06-2012, 01:14 AM   #1
Three bedrooms on same circuit?
Hey all,
I'm going to re-wire three adjacent bedrooms in my house. I want to put the receptacles for all three rooms on the same 20-amp circuit. about 6 receptacles per room, 18 in all.
Is that amount of receptacles within the limit of a 20-amp circuit, or too many? Lights and smoke detectors will be on separate circuits. Thanks.
bottlerockett is offline   Reply With Quote
Old 06-06-2012, 01:25 AM   #2
Licensed Electrician
k_buz's Avatar
Sure...there is no limit on the number of receptacles on a circuit. Common sense is telling me that you should put them on two circuits, but its not necessary.
Location...Location...Location
k_buz is online now   Reply With Quote
Old 06-06-2012, 01:42 AM   #3
Unless you're in Canada, or have a local code saying otherwise, there's no limit on devices per circuit
Techy is offline   Reply With Quote
Old 06-06-2012, 08:13 AM   #4
One routing stategy for two circuits is to run one to the wall between bedrooms #1 and #2 and the other to the wall between bedrooms #2 and #3. A circuit could serve receptacles on both sides of a wall.
Another strategy is to have three circuits, one for each bedroom.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 06-06-2012, 12:02 PM   #5
Thanks for the feedback. The main reason for putting all three rooms on the same circuit is that I'm running out of breaker space on my panel.
Old 06-06-2012, 12:29 PM   #6
kevinp22's Avatar
you might consider running it so there is a junction box very close to the panel fed from the panel and then branching out to either 2 circuits or a circuit for each room. that way, if you ever put in a larger panel or subpanel you can easily separate them into multiple circuits (run the wires in such a way that you could put each into a panel later without having to splice them). If you first go to one bedroom and then branch out, that later change will be much harder.
Wish I had thought of that when I was starting my project, to be honest
kevinp22 is offline   Reply With Quote
Old 06-06-2012, 01:38 PM   #7
Average Joe/ex-Navy IC3
gregzoll's Avatar
20 amp is overkill for bedrooms. You would do fine to do the outlets on a 15amp circuit, and have the lighting on the same 15amp lighting circuit for the hallway & bath.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 06-06-2012, 01:54 PM   #8
the Musigician
DangerMouse's Avatar
MY inspector would say to separate all 3 bedrooms to it's own 15 amp AFCI circuit.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-06-2012, 02:01 PM   #9
Code05's Avatar
DM
Guess what I would say to that inspector. Hint: it would not be polite.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
gregzoll (06-06-2012)
Old 06-06-2012, 02:07 PM   #10
kevinp22's Avatar
I would probably say with veiled sarcasm "I guesss that page fell out of my code book"
Old 06-06-2012, 02:14 PM   #11
the Musigician
Let me put it this way, that's what he made me do. I barely squeaked through with enough spaces on my panel. I was just about ready to go buy a new one or add a subpanel until I figured out a way to use a tandem for one space to make it two.
DM
Old 06-06-2012, 03:11 PM   #12
Code05's Avatar
DM
Just so we are clear here-you did it to shut him/her up, pass your install, and go away: I have done the same...
But no one makes me do something that is not written in code or amendments...
I may choose do it just to pacify an inspector if it minor, but if any real money or time is involved-nope.
The Following 3 Users Say Thank You to Code05 For This Useful Post:
kevinp22 (06-06-2012), stickboy1375 (06-06-2012), Techy (06-06-2012)
Old 06-06-2012, 09:17 PM   #13
Thanks all! But I still don't get it. Why is it better to split up the rooms on two or three circuits for receptacles only? Why is this something an inspector might suggest, even if the anticipated load of the receptacles is well within the capacity of a 20-amp circuit?
Old 06-06-2012, 09:38 PM   #14
Civil Engineer
The reason for having multiple circuits is pretty simple. If you plug a 12 amp vacuum cleaner into one outlet on the circuit, and a 5 amp device into another outlet on the same circuit, you are close to blowing the breaker. If you have a lot of permanent devices on the circuit, like computers, lights etc., you are going to have to be very careful to avoid overloading the circuit. Not dangerous, just a pain.
Old 06-06-2012, 09:50 PM   #15
In my area of the continent ,the max would be 12 and of course they would be arc fault.
IntexInspector is offline   Reply With Quote
Bathroom Fan/Outlets on Same Circuit rjschwar Electrical 6 04-22-2011 11:56 AM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
