Old 09-14-2011, 09:23 PM   #1
THQL & THQL-AC the same thing?
I want to replace 20A circuit with arc fault type. It's a GE panel with model numbers TM1410S/TM1410F. Says only to use TQP, TQL, TQL-AC, TQAL-AC, THQL-AC, THQAL-AC or TXQL breakers. I found this: http://tinyurl.com/3p5rte4 It has THQL in the model number, but is THQL the same as THQL-AC?
Sliding Man is offline   Reply With Quote
Old 09-15-2011, 06:14 AM   #2
Code05's Avatar
The breaker is correct as far as I can tell.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Sliding Man (09-16-2011)
Replacing a fiberglass curtain thing with an actual bedroom door. jde0503 General Discussion 9 08-05-2011 10:13 AM
What's the worst thing you've found after midnight? Leah Frances Off Topic 14 04-12-2011 02:10 PM
what is this 'cutting in' thing I'm hearing about in paint threads? joeyboy Painting 13 01-03-2008 03:34 PM
lost power to 1 thing in 4 different places... ManMythLegend Electrical 31 12-19-2007 01:57 PM
Is there such a thing? wiscborn Plumbing 6 06-29-2007 03:19 PM
