THNN Vs. THWN Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 10:12 PM   #16
Idiot Emeritus
Rewards Points: 1,468
I realize this is sort of late in the thread, but here's what the wire designation letters mean.
T=Thermoplastic insulation, 60C
H=15C higher. HH=30C higher.
W=Wet locations. Ok to submerge in water. The inside of a conduit installed in a wet location is considered a wet location.
N=Nylon outer covering.
THHN=90C insulation, dry locations only.
THWN=75C insulation, OK for wet locations.
Be careful with the 90C temperature rating though, the vast majority of terminations are rated for a maximum of 75C, and this is the ampacity column you must use in table 310.16 The 90C rating is useful when de-rating due to multiple conductors in the same conduit.
Rob
micromind is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
