THNN Vs. THWN Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 08:44 AM   #1
THNN Vs. THWN Wire
I went to Home Depot and Lowes for THWN wire for outside wiring in a conduit. They only carry THNN wire.
Should I use THNN or THWN ? I heard THWN is for wet locations like outside conduits. Where Can i buy this wire ?
indy is offline   Reply With Quote
Old 11-13-2009, 08:59 AM   #2
THWN has to be used in conduit outside
A lot of the THHN is also rated as THWN
They may only advertise it as THHN, you need to check the wire
Or go to a real electric supply
Old 11-13-2009, 09:11 AM   #3
Isn't THWN (thermoplastic high water resistant nylon) rated for direct burial? THHN is thermoplastic high heat resistant nylon. THNN is for damp locations not direct burial.
If you look at the wire and read the marking on the side it will say what it actually is, as you can imagine people get these acronyms mixed up.
Also sometimes it will be rated for more than one of these spec ie both THWN and THHN.
Salem747 is offline   Reply With Quote
Old 11-13-2009, 09:52 AM   #4
Electrical Contractor
kbsparky's Avatar
Most THHN is also dual rated as THWN and MTW. It may also have a suffix rating of -2, such as THHN-2 THWN-2 etc.
Look at the actual piece of wire, betcha all those ratings are printed on it!
-KB
Old 11-13-2009, 09:53 AM   #5
But the ultimate question, I guess, is: Can THWN be direct buried?
Old 11-13-2009, 10:02 AM   #6
No. It must be in a conduit or in an approved direct burial jacket.
jerryh3 is offline   Reply With Quote
Old 11-13-2009, 10:03 AM   #7
kbsparky's Avatar
NO.
-KB
Old 11-13-2009, 10:05 AM   #8
My home Despot sells direct burial cable that is in a black jacket. That's what I used for the garage, inspector had no problem with it. I assume that it is the THWN then. I wasn't thinking of loose wire but is the guy asking the question thinking loose wires or like a 3 conductor like I used???
Old 11-13-2009, 11:21 AM   #9
300zx's Avatar
Is this a sub panel in the garage if so you need to have 4 wires and seperate the ground and nuetral Or did you just run some rec to garage?
300zx is offline   Reply With Quote
Old 11-13-2009, 11:46 AM   #10
Dunno what you mean by "rec" but I ran 3 conductor #6 to the garage.
Old 11-13-2009, 11:48 AM   #11
3 conductor with ground?
That is what is required in the US
Old 11-13-2009, 11:52 AM   #12
Yes. 2 "blacks" 1 white and a bare ground. In Canada the ground for the sub has to be carried back to the main panel.
There was another guy on here that was doing a sub-panel and just installing a new ground at the sub, that wouldn't float in Canada.
Old 11-13-2009, 11:53 AM   #13
300zx's Avatar
receptacle(outlet) or did you put in a sub panel 3 #6 here would not pass inspection here you also need a ground and a few other things if this garage is detached!!!
Old 11-13-2009, 11:54 AM   #14
300zx's Avatar
Sorry you posted before me.
Old 11-13-2009, 12:07 PM   #15
Yeah, with my welder and stuff I wanted 60A in the garage, I installed a 100A Cutler-Hammer panel (In the US it might be Eaton), on a 60A breaker in the main panel. It is detached. I'm kicking myself a bit though, I put in a 30A circuit for my welder, put up the walls and then found a great deal on a use Miller 40A plasma cutter!!!
http://www.millerwelds.com/products/...spectrum_2050/
I decided to go with a new, smaller one that can run on 110V and 220V.
http://www.hypertherm.com/en/Product...powermax30.jsp
It might be a touch underpowered for some bigger stuff I may do sometime in the future but I like the 110V capability and the bigger ones are all 220V only.
Now that is a cool tool!!!
Now I kinna wanna leave work early to go home and play with it!!!
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
