Thinnest Possible Electrical Box? Or Alternatives? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 09:46 PM   #1
Rewards Points: 117
Thinnest possible electrical box? or alternatives?
Hi all,
Here's my dilemma. I really want to install a double slide-in-wall door, like the attached image. However on the same wall , I must also also install light switches close to the door opening. Because the door slides "into" the wall, using normal 2x4 framing walls, the pocket inside the wall would not allow any standard electrical boxes (in order to install a light switch there) to coexist inside that pocket as this would block the door's sliding path.
I'm guessing I could always make a 2x6 framing wall, but I prefer not to add extra thickness to the wall if possible. Therefore I'm wondering, if I stick with a 2x4 framing wall, is there such a thing as super thin electrical boxes? or anything else that can get around my problem? Thanks!
jsunsun is offline   Reply With Quote
Old 01-14-2013, 10:19 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
We've discussed this at length in the not so recent past. In my 15 years in the trade, the only way I have seen this problem addressed is to either fur out the wall, or move the switch to an alternate location. The minimum measurement from the face of the stud to the door would need to be just over 1 1/2".
The Following User Says Thank You to k_buz For This Useful Post:
jsunsun (01-14-2013)
Old 01-14-2013, 10:53 PM   #3
Rewards Points: 117
Thanks! guess I'll either fur out the wall or give up the sliding door idea and use conventional doors...
Old 01-14-2013, 11:11 PM   #4
joed's Avatar
Rewards Points: 11,992
Why can't you put the switch on the other side of the door or slide the door the other direction?
Old 01-14-2013, 11:14 PM   #5
Rewards Points: 117
I need to do a double door, so there is no other side. I can put it outside of the door pockets, but that won't be within arms reach as I walk into this room.
Old 01-14-2013, 11:23 PM   #6
Rewards Points: 117
Has anyone tried a wireless light switch like the one shown in this video?
I came across this, wondering if this could work? I could install the switch wiring somewhere else nearby and put the wireless switch by the doorway. Will this work?
Old 01-15-2013, 12:31 AM   #7
Engineer
Rewards Points: 161
Yes, that will work for what you're looking to do. My father in-law has something similar, and likes it. The switch isn't very estethically pleasing, but it works well for him.
diystephen is offline   Reply With Quote
Old 01-15-2013, 08:23 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Most pocket rood framing is 2x2's. You can use a standard depth (1-1/2") 1900 (4"x4") side strap box on the 2x2. You just have to be creative/careful running and securing the wires to and from the box.
The Following User Says Thank You to Speedy Petey For This Useful Post:
mpoulton (01-15-2013)
Old 01-15-2013, 08:34 AM   #9
Rewards Points: 320
How about an occupancy sensor switch further inside the room or on another wall?
http://www.globalindustrial.com/p/el...FVCd4Aod02cADg
teamo is offline   Reply With Quote
Old 01-15-2013, 09:04 AM   #10
Electrical Contractor
kbsparky's Avatar
You could use the device ring shown above by Speedy, and mount a switch there without a junction box. But you'll have to use a 24 volt relay mounted at the light and use class II wiring to make it legal.
No switch box needed.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Speedy Petey (01-15-2013)
Old 01-15-2013, 10:40 AM   #11
You can also check out Skylink, there are a few different options for wireless switches at a very affordable price. We are a dealer for them here in Canada and they are great products.
waynestractor is offline   Reply With Quote
Old 01-15-2013, 08:52 PM   #12
Rewards Points: 117
I have these in washrooms, but I don't want this room to have light turned on everytime someone passes by.
Old 01-15-2013, 08:54 PM   #13
Rewards Points: 117
Where can I get them? do you have a store front?
Old 01-15-2013, 09:03 PM   #14
We do not have a store front at this time. Where are you located, we can ship in Canada.
www.infocusled.ca
infocusled@yahoo.ca
Old 01-15-2013, 09:15 PM   #15
Rewards Points: 117
www.infocusled.ca
infocusled@yahoo.ca
Thanks Email sent!
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 11:49 AM
