Things Stopped Working W/o Tripping Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 10:29 AM   #1
hohadcr's Avatar
Rewards Points: 306
things stopped working w/o tripping breakers
I just rewired a whole room. Everything is quite straightforward.
I used breakers #1-#12. Other than 2-4, and 6-8, which are used for 240V heaters, everything else is just plugs.
This morning, it was cold, 240 heaters and small 110 heaters are all cranked up. Then, everything stopped working, but the plug on #1and #12 breaker.
Also, there seem to be some small voltage going to some other plugs and the lights can be lit but very dim.
Now,
1. am I right in saything that it is probably one of the main fuses that was burt, and caused one pole of the main 240 entry stopped working. (I am going to investigate the main fuses right away.)
2. am I right that #1 and #12 is on the same pole that is still working?
3. Assume it one pole's fuse that got burnt. Why only two plugs on the still working pole is still working?
thanks a lot
hohadcr is offline   Reply With Quote
Old 11-14-2011, 10:41 AM   #2
Sounds like you have a neutral problem. Check for loose neutrals if you throw a meter on your outlet and get a strange voltage 70-90v it is more than likely a neutral.
Colomboj is offline   Reply With Quote
Old 11-14-2011, 12:18 PM   #3
Rewards Points: 1,418
Are you sure that it's just the #1 and the #12 that are working?
Measure the voltage at each and every breaker screw (where the black or red wire is fastened) and write it all down. Any patterns such as every other breaker having a strange voltage?
Old 11-14-2011, 12:30 PM   #4
I=E/R
a7ecorsair's Avatar
If the 240 volt heaters stopped working then there is no reason to jump on the neutral as being bad or loose.
OP, If you are going to work with, and troubleshoot, electrical problems you will need a meter. You said breakers 2/4 and 6/8 are two pole breakers so just measure the voltage across the two connection points.
a7ecorsair is offline   Reply With Quote
Old 11-14-2011, 12:48 PM   #5
hohadcr's Avatar
Rewards Points: 306
checked plugs , its 10-15volts,
checked neutral connections, don't see anything loosen.
checked main fuses, burnt one.
changed both fuses everything working again.
its a 60a fuse.
still, why only 2 of all the plugs on the unburnt fuse were working?
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 16 12-03-2016 09:31 AM
Kitchen light/ceiling fan has stopped working? glamgirrl Electrical 5 07-11-2011 09:31 PM
Payne 376C Stopped working dhigginx HVAC 5 05-31-2011 08:19 PM
Carrier Heat Pump stopped working burnselk HVAC 2 02-06-2010 01:30 AM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 10:47 PM
