THHN For Ground To Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 11:54 AM   #1
Question
THHN for ground to sub panel
It seems like I always have one last question. I'm very grateful that you guys are so tolerant.
Anyway, the #8 THHN Type wire that InPhase277 recommended from first panel to subpanel says "to use in conduit". Is this required by code since its just to connect the grounds? All of the previous wiring was buried. I thought I would just run this ground wire through the rafters to avoid cutting into the existing buried cable and the water lines.
nprranch is offline   Reply With Quote
Old 12-23-2008, 01:35 PM   #2
Rewards Points: 2,350
I learn more every time you post! I'm pretty thick, so I guess I just assumed that the wiring to the subpanel was run overhead in the rafters, or otherwise exposed. I was thinking you could run the new ground wire beside the original cable. But, at any rate, for the sake of safety gained by installing this ground, I wouldn't be too concerned about running the wire. THHN is meant for use in conduit, because you don't want to run live conductors exposed. In this case, because you are following behind some bad work and trying to make it safe, I don't think it is a problem.
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
