THHN Colors - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 07:31 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
THHN Colors
HI;
Say I have a big spool of THHN that is black that I would like to use, with prices of wire so high, If I could use up this spool for a run that would be ideal.
Is it legal to use this and tape the ends with the correct colors or does neutral always have to be white with THHN?
Are the rules any different with different gages, i.e. heavier wire is harder to find in multiple colors for example.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-10-2008, 07:42 PM   #2
Legally you can only reidentify #4 and larger.
As far as violations, this is like jay walking.
IMO of course.
220/221 is offline   Reply With Quote
Old 10-10-2008, 08:12 PM   #3
joed's Avatar
Rewards Points: 12,420
You can use it for hot wires only. You can not recolour it for use as a neutral or ground.
Old 10-10-2008, 09:02 PM   #4
Registered User
Termite's Avatar
Although I'd discourage you from doing it, I have to agree with 220/221's jaywalking analogy. I wouldn't turn a homeowner down for doing it assuming the wire was properly color-indicated (thoroughly) at every box and termination point. I'd chastise a professional for doing it and would be less inclined to accept it, but would probably allow it on a very limited basis.
Your best bet is to check with your inspector to make sure he's not going to give you a hard time for it.
Old 10-10-2008, 09:21 PM   #5
dSilanskas's Avatar
I've seen it done before I dont think its bad. Wrong perhaps but not bad
dSilanskas is offline   Reply With Quote
Old 10-11-2008, 09:39 AM   #6
Rewards Points: 126
What size is it?
Old 10-11-2008, 10:12 AM   #7
DIY'er
jamiedolan's Avatar
Originally Posted by J. V. View Post
What size is it?
I have some 6, and a couple spools of 12 and 14. I saw a good deal of a spool of 8, and was considering running that for a project.
It was really the heavier stuff that I was thinking of doing it with because the cost isn't all that high with the 12 and 14. I might used them up wiring the contact sensors on my garage door. So my questions really mainly applied to 8 gage and heavier.
Jamie
Old 10-11-2008, 11:46 AM   #8
Electrician
SD515's Avatar
Rewards Points: 504
I agree with 220/221 and especially with KC's comments. Though code-wise it's not correct to re-identify #6 and smaller, doing it to #6 & #8 in a limited situation might be ok with your inspector...if you can sweet talk him into it.
Kyle
Old 10-11-2008, 11:52 AM   #9
Rewards Points: 506
Send a message via AIM to theatretch85
Personally I hope that it is considered "ok" in that a recent project I was converting a 240 only circuit into a 120/240 circuit by running a neutral wire (its all in 1" conduit). I had to put in 2 outlets of different configurations (one is for a 3 wire welder, the other for a 4 wire portable sub panel. All I had to make pigtails out of was #6 white, so I wrapped electrical tape around the pigtails the entire length (only about 8-12") and color coded them to match the supply wires. The neutral wire is white the entire length from the panel to the outlet box and right into the 4-wire outlet itself; the short pigtails are the only thing I re-colorcoded.
theatretch85 is offline   Reply With Quote
Old 10-11-2008, 12:00 PM   #10
Registered User
Termite's Avatar
If I encountered this scenario on an inspection, I would ask the electrician to use some vinyl tape to color-indicate the actual run of wire by the wire nut in addition to using the correct color of pigtail wire. In my opinion, that makes the setup more deliberate looking, and would remove anyone's doubt or suspicion of what each wire is doing.
It is one of those situations where doing what the inspector wants is sure better than the code-compliant alternative!
Old 10-11-2008, 12:11 PM   #11
Rewards Points: 506
I know its not the best scenario, and believe me if I had a couple short pieces of #6 in black that I could re-color Red and Blue, I would have used that. But I figured if I completely covered the white pigtails end to end with electrical tape (you can barely tell it was white) that would be more acceptable than just a strip on the ends with it largely being white.
Old 10-11-2008, 12:20 PM   #12
DIY'er
jamiedolan's Avatar
For this short of run, why wouldn't you just buy the right wire? HD sells it by the foot, your only talking about a few dollars.
I only asked this question because I have about 1500 feet of thhn laying around right now. If there was a short run, I would not hesitate to just buy the proper wire and do it right.
Jamie
picking colors?? emily225566 Painting 6 03-31-2008 10:00 AM
Painting a room different colors carldjensen Interior Decorating 5 11-08-2007 08:49 AM
Sites to "virtually" change paint colors? Shpigford Painting 3 11-02-2007 06:10 PM
Ideas for shutter colors for sterling grey siding. patt Painting 1 05-23-2007 07:21 PM
faux paint colors KCpainter Painting 3 02-01-2004 06:03 PM
