Are These Pushmatic Breakers Available? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 11:16 AM   #1
Rewards Points: 27
Hi all,
I am trying to add a new breaker to my existing box, the house has too much stuff connected and a couple of wires are double tapped.
Here are a couple of pics of what I have. There is space for a couple of new breakers, but I can't seem to find them locally.
Any suggestions appreciated.
Hugh
hugh71158 is offline   Reply With Quote
Old 02-02-2011, 11:28 AM   #2
Licensed electrician
Rewards Points: 1,864
They are available, but you will need to get them from suppliers that handle obsolete breakers. Expect about $40 or so for a single pole IIRC.
Old 02-02-2011, 11:30 AM   #3
DIY staff
Rewards Points: 7,174
Push-Matics are still available at my local electrical supply house---bring a full wallet--
Villa Park Electric supply---I'll come back if I can find a link---Mike--
http://www.vpes.net/ --found it.
Old 02-02-2011, 11:48 AM   #4
Rewards Points: 27
Gentlemen, that was fast!!! Awesome forum. Thanks for the link Mike.
A couple of questions:
1. I read something about pushmatic breakers being a little suspect in their ability to perform with age. Anyone heard that?
2. Relative to the above point, if I am going to pay so much for a breaker should I simply buy a new, safer, box?
Thanks for the replies.
Hugh
Old 02-02-2011, 12:00 PM   #5
While the individual breaker price would be less for a current breaker, there would be the additional cost of the panel changeout. These can be quite labor intensive aka expensive.
Old 02-02-2011, 12:17 PM   #6
Hugh
Pushmatics sometimes don't age very well. The key to keeping them working is to cycle the breakers periodically to keep the moving parts, well, moving.
Unless you are having problems with the service panel, it'd be far less expensive to maintain a working panel than to replace it (assuming that the panel is in good condition and is properly wired). If the panel is in good shape and is wired correctly, I would not be worried. If you plan to do lots of expansion in the future, you might consider upgrading the panel to make work easier and less expensive down the road.
clashley is offline   Reply With Quote
Old 02-02-2011, 12:53 PM   #7
Rewards Points: 27
Guys,
thanks a lot!
The panel is probably fine and I just want to add one, maybe two circuits, for which there is expansion space.
Thanks again.
Hugh
Old 02-02-2011, 12:57 PM   #8
DIY staff
Dito ---service upgrades and box change outs are a substantial investment---good to do if you have out grown the service---We are an all conduit area---upgrades here cost $1200 and up--
a good value if needed---waste of money if not.
Old 02-02-2011, 06:01 PM   #9
Rewards Points: 27
Hmm, I was quoted $98 online, but I managed to find a double one at Home Depot for $49. THIS IS IT
Seems expensive, but not as bad as some.
Thanks again.
Hugh
Old 02-02-2011, 07:11 PM   #10
Licensed Engineer
Rewards Points: 175
I needed a 20a/15a duplex single pole Push-A-Matic breaker. I also bought one of the newly manufactured Push-A-Matic style equivalent breakers like you found at Home Depot. All the authentic ITE brand obsolete Push-A-Matic breakers I found were used and not New Old Stock breakers.
I would rather have a new breaker than pay more money just so everything in the panel board matched in appearance.
MI-Roger is offline   Reply With Quote
Where can Pushmatic breakers be bought? peterthomas3 Electrical 24 08-05-2013 06:45 PM
Different styles of pushmatic breakers (bolt spacing/ location) codeman112 Electrical 24 11-24-2010 10:36 AM
Can I get AFCI breakers for my panel? BlueBSH Electrical 21 08-04-2010 07:07 AM
Pushmatic Panel, no main, no 2.p. breakers avery2008 Electrical 8 05-02-2009 02:51 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
