Are These Lighting Code Requirements In CA For Real? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2014, 04:14 PM   #1
Rewards Points: 574
Are these lighting code requirements in CA for real?
I've been told that if you remodel your bathroom, to get permits you can only install either LED lights or those energy saving mercury bulbs. No incandescent, no flourescent, no halogen. Is this for real? This is in Southern California.
darsunt is offline   Reply With Quote
Old 07-21-2014, 04:29 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,950
California is pretty tough with the ECO police, it wouldn't surprise me if it were true.
stickboy1375 is online now   Reply With Quote
Old 07-21-2014, 04:36 PM   #3
Licensed electrician
Rewards Points: 3,628
You might want to look up Title 24 requirements.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
ddawg16 (07-21-2014), stickboy1375 (07-21-2014)
Old 07-21-2014, 05:04 PM   #4
PoleCat's Avatar
Rewards Points: 1,606
Who gets a permit to remodel a bathroom?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-21-2014, 05:15 PM   #5
E2 Electrician
Any legit contractor, so if we have to, why shouldn't you?
Old 07-21-2014, 06:38 PM   #6
Retired from the grind
gregzoll's Avatar
Rewards Points: 4,252
People that live in California.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
mpoulton (07-21-2014), MTN REMODEL LLC (07-22-2014)
Old 07-21-2014, 07:38 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 4,156
That is the one.....
Please guys....spare the California comments....once you get into title 24...it's pretty straight forward.
In a nut shell....it has to be high efficacy lighting. CLF qualifies....if you use pin style or GU24 base. Edison base light fixtures, regardless of the bulb in them, are not title 24 compliant....you might have an LED bulb in there...but it doesn't stop someone from removing it and putting in an incandescent.
As for permits....I'm willing to be just about all large cities require permits when you make modifications to plumbing or electrical. Replacing a vanity is not a remodel....a new floor is not a remodel....ripping out the bathtub and putting in a new one? Yea...that is a remodel....and needs a permit. You would be surprised at how many get it wrong.
I only have 1 incandescent bulb in my house....the oven. I even converted the fridge to LED.
I should add that you can use Edison based fixtures if you have them on a dimmer and/or occupancy sensor.
My wife and kids do NOT know what the off switch is. It kills me to come home after dark and every bloody light in the house is on...and most of the rooms are empty. I have installed occupancy sensors in all the bedrooms and baths. It works real well for my boys and their long showers. I have them set for 5 min...if the light goes off while they are in the shower...they know it's time to finish...of course all they have to do is stick their hand out of the shower and the light comes back on.
One other benefit to all those 'new' bulbs....I don't stock bulbs any more. So far, the only time I buy a bulb is when I'm putting in a new fixture.
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
AndyGump (07-22-2014), CarpenterSFO (07-22-2014), MTN REMODEL LLC (07-22-2014)
Old 07-21-2014, 07:49 PM   #8
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 260
California sucks an enormous amount of juice off the grid and they're doing what they can to cut it. The power is available but the infrastructure is near its capacity in areas.
clw1963 is offline   Reply With Quote
Old 07-21-2014, 11:44 PM   #9
Oso954's Avatar
Rewards Points: 2,800
That does not meet the current requirements of title 24 for bathrooms. You must have one high efficacy fixture. Other non high efficacy fixtures must be vacancy sensor controlled ( manual on, auto off)
Oso954 is offline   Reply With Quote
Old 07-22-2014, 12:38 AM   #10
JOATMON
ddawg16's Avatar
Your assuming that light is not high efficacy.....recall that I mentioned I had only one incandescent bulb in the house?
All the bathroom lights are high efficacy....in fact, ALL lights are high efficacy. I'm in compliance.
Side note....I have 2 sets of lights in the bathrooms. The first one is a combination vent fan/light. The second light is over the vanity. You can't turn on the vanity light without turning on the vent/light first....which is also on the occupancy sensor. So...when the wife and kids walk out of the bathroom...5 min later....ALL lights turn off.
But during the day....we really don't need to turn on a light....I have this....sun tube.....
We got a good laugh a couple of weeks ago...my oldest daughter stopped by....and spent 5 min trying to turn the sun tube off.....
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 07-22-2014, 01:28 AM   #11
Pro
Originally Posted by ddawg16 View Post
...You can't turn on the vanity light without turning on the vent/light first....which is also on the occupancy sensor. So...when the wife and kids walk out of the bathroom...5 min later....ALL lights turn off.
FYI, from the residential rules:
B. ExhaustFans
There are two options for the switching of lighting associated with exhaust fans:
1. All lighting shall be switched separately from exhaust fans, or
2. For an exhaust fan with an integral lighting system, it shall be possible for the lighting system to be manually turned on and off while allowing the fan to continue to operate for an extended period of time.
An exhaust fan may need to run continuously if used to comply with 150.0(o).
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Old 07-22-2014, 01:33 AM   #12
Pro
As DDawg points out, it's not all that hard to do, or to understand. Here's the manual. Chapter 6 is the main residential bit:
http://www.energy.ca.gov/title24/201...al_manual.html
There are some great LED fixtures out there, with nice warm light for the bathroom.
Robert Cram
The Following User Says Thank You to CarpenterSFO For This Useful Post:
clw1963 (07-22-2014)
Old 07-22-2014, 09:19 AM   #13
Electrician
Rewards Points: 3,482
Im glad Im not in Cali Not offence, just saying
Jump-start is offline   Reply With Quote
Old 07-22-2014, 09:21 AM   #14
Electrician
SCE has to be the worst offender. The stuff Ive heard them push beyond 80 years
Old 07-22-2014, 09:41 AM   #15
PoleCat's Avatar
Around here a homeowner can just do what he wants with his own bathroom without asking for approval. I have to admit I like it that way. Contractors always are supposed to pull a permit but many of them don't.
Reasonableness and Code Requirements? Cricket Controversial Board Room 29 03-27-2014 05:14 PM
Pool conduit code requirements bigcaddy Building & Construction 1 09-23-2013 11:30 AM
Living Room Lighting Requirements jackwashere Electrical 4 09-19-2013 06:13 AM
Code requirements for remodel wiring? Mills314 Electrical 2 01-15-2012 08:25 PM
lighting disco code Steven Jackson Electrical 4 02-18-2009 06:12 PM
