Thermostat Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 07:58 PM   #1
Question
Thermostat wiring
I am new so pls understand. I am replacing an old Arcoaire thermostat for a heating and cooling heat pump. The existing wire reads like this:
C
G
R
Y
O
W1 jumpered to E
The new digital thermostat has all the wiring letters (colors) but W1
I call the trouble desk for the company and they suggested to contact an electrical contractor. I am on a budget, where does W1 go? and is it stll jumpered to E.
Tks Sherio
sherio13 is offline   Reply With Quote
Old 01-15-2010, 08:14 AM   #2
Remodeling Contractor
But the white wire on the W1 terminal.
Old 01-15-2010, 08:56 AM   #3
Rewards Points: 6,652
Need make & model of the thermostat, heat pump, air handler. Also, if you can post a pic of the circuit board were the wiring connects (please no super close up), that helps, if you cannot figure out the directions of the thermostat & air handler.
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 08:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
