Thermostat Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 12:52 AM   #1
toolbelt Tina's Avatar
thermostat wiring
I have a programmable digital thermostat I am attempting to install for my baseboard heaters in the cottage.
The instructions to connect are next to nil. Two wires on thermostat.
Is it like a light switch? Line or black hot to therm. Load black to other wire on therm.
What about multiple heaters on the same line? I have a kitchen living room situation, the kitchen heater was removed in the reno. I am left with a line wire and a load wire to the living room. I require a therm and heater for kitchen and a therm for the living room.
Are there more efficient electric heaters on the market or are they all the same?
Tina
toolbelt Tina is offline   Reply With Quote
Old 10-04-2009, 05:02 AM   #2
Electrical Contractor
kbsparky's Avatar
What is the make/model number of the thermostat? Are you dealing with "line voltage" or low voltage?
-KB
Old 10-05-2009, 10:28 PM   #3
Noma Heating Programmable Thermostat model htm611a/ 52 2544-0
for high voltage electric baseboards
max load 3000 w @240
1500w@120v
12A
min load 500w
http://www.upm-marketing.com/images/..._Downloads.pdf
Old 10-06-2009, 04:15 AM   #4
kbsparky's Avatar
Yes, line voltage thermostats are basically a switch. You have 2 wires: One is the "line" and the other is the "load"
How many wires are in the wall box where the thermostat will be mounted?
-KB
Old 10-06-2009, 10:58 PM   #5
Thanks for all the help.
All the thermostats were using low voltage thermostats that were not accurate.
At the baseboard level in the kitchen I have 2 wires, 1 is hot the other goes to the living room baseboards.
Will I pigtail it to run two thermostats?
cheers Tina
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
