Thermostat Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 08:38 PM   #1
thermostat wires
new thermostat honeywellCT50K has letters for wire connection. old thermostat has no letters just1 black 1 white wire.How do you connect them.
Turko is offline   Reply With Quote
Old 10-10-2011, 08:40 PM   #2
Electrical Contractor
kbsparky's Avatar
How thick are those wires?
What are you controlling with this thermostat? Electric heat?
You can not use this model for line voltage control of electric heat units.
-KB
Old 10-10-2011, 08:44 PM   #3
colored wires
The wires are quite thin and are connected to the back of our old thermostat.We need to hook them up to new thermostat but dont know which wire is which because new thermostat uses letters on connections and old one does not.It is the proper thermostat, purchased at rona.It is a gas heater.
Old 10-10-2011, 08:51 PM   #4
Mad Scientist
I'd repost this over in the HVAC area for a more definite answer, but I believe one wire goes to RH or R, whichever you've got, and the other to W. For such a simple connection, I don't believe it matters which wire is which.
McSteve is offline   Reply With Quote
Old 10-10-2011, 09:15 PM   #5
kbsparky's Avatar
With only 2 wires, it really doesn't matter which one is which.
You want to use the R and W terminals for heating on a 2-wire system.
-KB
Old 10-10-2011, 09:29 PM   #6
wires - thermostat
Black- R/RW
White- W
thestig3 is offline   Reply With Quote
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
2 stage thermostat with old wiring (4 wires)? bigbug HVAC 2 06-22-2010 12:34 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
